St4cky
(Stacky)
January 21, 2019, 6:15pm
1
Hi so basically I want to build a micro Quadcopter and transmit the Video feed to my computer.
My question is: Is it possible to transmit the Video Feed that OpenCV on my computer can command the quadcopter wirelessly.
So that I dont have to put a raspberry on my quadcopter (It actually couldnt lift it).
Or if I understand it wrong I’m sorry.
ppoirier
(ppoirier)
January 21, 2019, 7:13pm
2
Yes it is possible , you can check on these experiments:
I would like to show my work (in progress) on a simple system capable to realize indoor autonomous flight.
The system is based on a quadcopter with a camera that stream video (and telemetry) to a desktop PC and receive pose estimation message and command from the same PC.
The camera is downward looking and on the floor there is an Aruco Boards like this:
[ppp]
The pose estimation is calculated by aruco_gridboard ROS package on the PC and the relevant messages are sent back to the quadcopte…
Hi all,
I am trying to autonomously control my Skyviper drone in a map consisting numerous Aruco markers on a plane. I am able to localize my drone by using the aruco detection and pose estimation libraries that OpenCV provides. I have written a ros node that publishes /mavros/vision_position/pose which contains the pose of the drone in NED coordinate system. I have whitelisted vision* and local* plugins in the apm_pluginlist.
Then I switch on my drone and connect my PC to it via WiFi. Next, I…
St4cky
(Stacky)
January 21, 2019, 10:39pm
3
He mounted the Raspberry Pi 0 on the quadcopter what I wanted to avoid.
ppoirier
(ppoirier)
January 22, 2019, 12:12am
4
The RPI zero is used to send video over wifi to the remote OpenCV, please read throughfully
St4cky
(Stacky)
January 22, 2019, 9:38pm
5
Yeah but the RPi 0 is mounted on the quadcopter.
Is it possible to use the MavLink connection to send the Video Feed to an RPi with OpenCV installed and the RPi to send commands back to the Micro APM via Mavlink?
ppoirier
(ppoirier)
January 22, 2019, 10:00pm
6
Nope Mavlink is telemetry
St4cky
(Stacky)
January 22, 2019, 10:03pm
7
yeah but I can control the Quad over Mavlink with MissionPlanner…so it should be possible to send commands to the Quadcopter
ppoirier
(ppoirier)
January 22, 2019, 10:14pm
8
Yes but not video , it has to be wifi or analog
I gave you 2 wifi methofs on the links
St4cky
(Stacky)
January 23, 2019, 6:14pm
9
Hmm then I didn’t properly understand the OSD with the Telemetry
dkemxr
(Dave)
January 23, 2019, 6:22pm
10
OSD isn’t live video, it’s a video overlay of data.
ppoirier
(ppoirier)
January 23, 2019, 6:23pm
11
OSD is a microcontroler (AVR , STM or other) that reads MavLink Messages and output to a character generator that is mixing (overlay video) an analog signal from an onboard camera and transmit the resulting over RF using analog transmitter generally on 5,8 Ghz
Here is the current status. https://youtu.be/LG6GBwN-igY
Here I am doing a 4m square with skyviper
