Looking promising here. I see you can tether the Transmitter to a laptop running Win 10 and Mission planner.
It would be great if this connection could be done over short range Wifi in the future.
But at least this way you can upload a mission from a laptop to the drone I assume and then unplug the USB then go fly but monitor the flight on the Transmitter?
I will likely pick one of these up shortly for testing.
I can request various kinds of information such as communication status using mk15 uart sdk, But can I request it to a port other than uart? For example, udp or… Whatever. As I applied sdk to uart, I think there will be confusion because it overlaps with mavlink communication.
Hi SIYI, I am facing issues in
mk15 with one of the mk15 transmitters I am having double yellow blinks when referring to the manual it represents transmitter Bluetooth is not identified. can you please suggest to me how I could solve this? and with another mk15 transmitter, the transmitter doesn’t pair with any receiver. I also checked with the same initial bootloader with both transmitter and receiver ends. @SIYI
I did update the firmware in the transmitter and receiver and still, I am getting the same issue. and can you also help me with reason why another mk15 transmitter doesn’t bind with any of the receivers?
yes sir the issue is solved with the yellow lights blinking. can you please give me a heads up on what might be the problem with one of mk15 that doesn’t bind with any of the receivers?
I assume that this MK15 system is successfully binded. Otherwise you do not see both RC and air unit firmware in the same page.
What is the firmware version of the MK15 remote controller which does not bind with any air units? Please connect that unit alone to the program to check firmware version.
Well, the picture shows that firmware is correct and it is already binded.
In what way do you judge that this MK15 unit does not bind? Can you show us a video of its indicator status under current situation?
