So, you mean I can do this?
Yes, this is correct and it will work
The special cable to connect telemetry to pc is just a jst on one side and usb on the other?
Video doesnāt go trough the same connection?
That cable is for firmware upgrade or telemetry output. Video stream can be output through the HDMI port.
Not in mission planner, should implement Ethernet output like herelink, at least trough an USB Ethernet adapter
Is it very necessary to have both telemetry and video gone through the same way in wire? Canāt them be separate or separately wirelessly?
And why is it still necessary to output telemetry and video to a PC since MK15 already has a monitor and runs GCS in Android?
We will appreciate it very much if you can explain. Thanks!
Yes it is important for people that want to use MP on a pc because they have it customized and have other software going on the pc too. For us at least it is very important and that is why we mainly use Herelink at the moment.
I mean you have all the hardware already in place, just route mavlink and video to an external pc conneced by wifi or ethernet (your own ethernet or an usb adapter).
Another issue is that if you have telemetry on one cable and video on hdmi than you need a pc AND a monitor, very unconfortable at the field of operation.
Many thanks for your reply.
Iām afraid that on MK15 there is no such a port to output telemetry and video directly or such a port to be converted.
The function you mentioned has been working on the new model HM30. On HM30, both stream (data and video) can go through the same way in wire (Ethernet) and wirelessly (WiFi).
And if there were a new model in the future, we will combine the function for sure.
I donāt understand why you canāt implement it on the mk15. It has wifi and an usb port for an external ethernet adapter. It can be done in several different ways with the hardware you have. It is only a matter of software not hardware.
How about telemetry through Bluetooth and video stream through WiFi hotspot? Both wirelessly. It is already available on your unit
Unfortunetly the bluetooth for telemetry only works with android
It does not make sense. Is there a video or some pictures to show the problem?
So i think the answer is that the radio software is not capable of forwarding telemetry and video to a pc attached with wifi or with an usb ethernet dongle. Unless you want to have 1 pc for telemetry and 1 monitor for hdmi video, that in my opinion is a solution that shouldnāt even be proposed, unless of course you donāt know what you are talking about
Can we get root acces to the radio so that we can do on our own what we need?
Hi, I need the remote last firmware pls, whatsapp doesnt awnser any more!
Have you tried Bluetooth for telemetry and WiFi for video stream? This one will work for sure.
Where we can download latest firmware?
Will try bt and wifi
Thank you very much.
Frank do you confirm it?
This is Franks Drive. He sent it to me a few weeks ago so the location should be good. Now thatās not to say he has something newer thatās not posted thereā¦ That I Cantā say. But he is usually pretty good at keeping it up to date.
Thank you very much!!
