There could be a mis-understanding.
I think they refer to Ethernet/HDMI support from MK15 receiver to IP camera or HDMI camera.
And the transmitter supports HDMI output as well. There is no Ethernet output on MK15 transmitter.
Through the upgrade port at bottom MK15 transmitter.
The diagram picture explains it well. And you can find more detail in the manual.
I will continue to report in the next few days, but I still have to finish building my new copter. After that I can also write more about the āhandlingā of the MK15 while flying.
What else I wanted to mention yesterday. The touchscreen does not always react to an input, but you have to tap it several times, before something happens. I noticed this yesterday while setting the switch assignments when I wanted to adjust the values for the respective position.
On the other hand, I noticed the performance of the MK15 very positively compared to the AK28, there are āworldsā in between. Itās like switching from a āVW Beetleā to a āFerrariā.
Today I put to the test your 2.4ghz datalink, a hard one, out 20+km 2000mt altitude, I had a loose antenna so I had a problem with the connection from time to time, but with the standard 5dbi antennas, was great, not super-fast refresh rate but it was wonderful, with a parabolic antenna ad a tracker it can do a lot more.
Very very pleased and impressed form your product.
Only one question, the microswitch on the side selects something?
Hi Steri,
Could you show us where to assign the switches inside QGC and explain a little about DO commands, please? We will have a try based on your information
