@SIYI
I am trying to make a gcs for mk15 with rtsp player. I am using gstreamer but can not figure out the flags to use. Can you please tell me what flags FPV app uses to building the pipeline.
I’m not sure what flags really means.
Welcome to refer to the SIYI FPV SDK for developing your own GCS.
https://drive.google.com/drive/folders/1LwiTAOVnlGyZ1k4RFJHyKzmMIQSOYIMt?usp=sharing
Hi Frank,
Have to say the MK15 is rather impressive.
I have two minor issues I’ve been trying to resolve:
The Map within SIYI FPV App is not updating to my location. However, it is showing my location with a marker. It always switches back to a location west out at sea of the coast of Africa. (Indicated by a blue marker.) - Also place Names are not in English. (App. version 2.5.8.404.a2f68b6)
Is there a way to force update to my location ? -
Is there anyone out there who could kindly supply the exact RTSP settings for MP?
Haven’t been able to get video streaming in MP, but fine in SIYI App and in QGC.
I did try to use settings as mentioned in the 30KM transmitter, but didn’t work for me.
rtspsrc location=rtsp://192.168.144.25:8554/main.264 latency=0 ! queue ! application/x-rtp ! rtph265depay ! avdec_h265 ! videoconvert ! video/x-raw,format=BGRA ! appsink name=outsink
Thank you for using MK15.
The SIYI FPV App is not a full function GCS, so the map function is for testing only at this stage. Please don’t reply on it much.
As far as I know, Mission Planner does not support direct video stream display from SIYI systems like QGC. Unfortunately.
@SIYI
Thanks Frank for your prompt reply.
No worries, won’t use the Map then until a later release of the SIYI FPV app.
Apparently Yuri_Rage got it working on the 30Km Transmitter link that you also sell, that’s why I’ve tried it.
Karl,
Just checked, on my Mission Planner ->Gstreamer Source I have this exact string and remember to have the video in the HUD of Mission Planner from the HM30 although with a latency of about 3 seconds so wasn’t too happy about it.
What I would suggest is first to start using Qgroundcontrol and verify your video is displayed OK. For me that worked very well. I do use MP but with the Video on a separate HDMI screen.
@champ8242
Thanks for that.
Yes, QGC works fine.
At times just prefer the HUD in MP with everything on the one screen (except map), but this can be adjusted by adjusting screen size of HUD and MP to be side by side.
Will try the HDMI screen solution, but my initial indication was that it will show exact copy the MK15 screen.
…unless it is possible to just sent the live video stream across. - Will try.
@Michael_Oborne
Just to clarify: Is RTSP supported in the MP Android version?
Or is latency the problem there in Android?
- Thanks
@SIYI, I use the following Gstreamer string in Mission Planner with the HM30 ground unit connected via wired Ethernet (under Windows 11):
If I recall correctly, latency was well under 100ms when I tested it, and it sufficed for basic control of my Rover, though I wouldn’t trust it for close-in obstacles.
Video latency using the available HDMI converter from SIYI was similar and very acceptable, but the direct wired Ethernet connection eliminates that hardware and the need for HDMI capture software/hardware if a computer is the intended display.
Video latency over the HM30 WiFi stream was far worse (on the order of seconds), and I abandoned it.
I have not tested on any OS other than Windows 11 nor any GCS other than Mission Planner.
Just to provide some more information and perhaps someone happens to know a solution:
This is the message that pops up when using Yuri’s settings for RTSP.
Karl,
This is not (yet) a rtsp error. It looks to me a user rights issue on GStreamer. If you are running it on a Windows machine, try to run MP as administrator and see if that helps
@champ8242
User rights were my first thoughts too. But as it is Android on the MK15 I thought that should not be an issue.
Ahh, sure. In that case, can’t help but for use it’s a GStreamer issue, not yet rtsp.
I’ve done a bit more research into that gstreamer issue in MP on Android 9 within MK15.
If I understand it correctly it is a permission issue within gstreamer as it requires root privileges which have to be set at time of installation (obviously prepared earlier as part of the MP for Android package).
It may also require specific access rights to the stream source - which, if I understand it correctly, would perhaps need a specific custom version of MP for the SIYI MK15 unit.
@Michael_Oborne
…would be nice hearing the official explanation from the man himself.
For those interested I’ve made an antenna mount for the MK15 receiver antennas. (3D Printing)
This design is suitable for 25mm carbon fibre tubing.
I think it will be good for the HM30 antennas as well. Top
Hello, was wondering if a bridge between radio wifi and on board ethernet has been introduced in latest firmwares.
I would like to connect to the radio wifi or ethernet dongle and reach the onboard ethernet, like the herelink can do.
Here is a 3D printable holder for the MK15 so a neck strap can be used.
Any news on the bridge from wifi to onboard?
