I am working on a large hexacopter myself with a similar setup (30 Inch Props on 100KV Motor). I have completed the assembly and Pixhawk setup and done all the tuning setup according to the new tuning guide. I will be attempting a first flight soon and wanted to know your experience with first flight and what changes did you made from default parameters specifically the PID gains.
How different are the gains now after tuning and fine tuning. A screenshot of Extended Tuning page from Mission Planner before and after tuning would be a great help, or perhaps you could share the .param file.
First flight was with default PIDs. After conducting an auto tune PID values were in the middle of the specified range, I can post the specifics at a later date, but not at the moment as the aircraft is being used for a project. Do be cautious with the values after the tune as we attempted a tune with the aircraft that returned very low values, around 0.6. We are not sure what caused this, after a crash and a second tune we got values that made more sense.
With default PID gains and MOT_THST_EXPO set appropriately you should be able to safely fly the aircraft. Best of luck!
Iâve got a question regarding prop size and Octoquad/X8 config;
A few key parameters can have initial settings based on prop size, so how do we treat the X8 with two props (the same size in this case) on one arm?
I think we would still treat this as just one size, for example 1555 props upper and lower = 15 inches in all the above posts and parameters, and we wouldnât try to sum them (30 inches) or do anything special.
Iâm not as sure about an X8 config with different size props (and possibly different motors too) for top and bottom. For example, upper props are 1855 (18 inches) and lower props are 1555 (15 inches) probably with high KV motors for lower props.
Would we :
Try and average the two, 16.5 inches in the example
Pick whichever you think will have the most effect (thrust, drag) 18 inches
and use that for the calcs in the new tuning guide.
Although Iâm using props of the same size and same KV motors for upper and lower, I read where people think thereâs merit in using slightly smaller higher pitch lower props and high KV lower motors - so I wonder about the tuning intricacies of such a config. Still Iâm suspecting the difference in prop sizes (and potentially coupled with motor KV) wouldnât make much difference.
If you want better than that you need to start measuring the thrust curve.
Yes there are lots of theories out there but most of the data has been produced without considering how multirotors are configured. For example most of the data is based on torque matched upper and lower blades. This is not the way an X8 aircraft will drive the props so it is not relevant for those aircraft.
I put together this spreadsheet for calculating some initial values based on the new tuning guide. You will need to judge for yourself if the calculated values suit your craft.
You should probably read and understand the new tuning guide to know what these new values mean. https://ardupilot.org/copter/docs/tuning-process-instructions.html
WARNING: formulas are derived purely on eye-balling the graphs in @Leonardthall 's guide and recreating them to gain some formulas. The graphs I recreated are on separate tabs and you donât need to look at them unless you feel like updating them and putting changed formulas back into the main tab.
Enter your prop size in inches, and the number of LiPo cells.
Copy/Paste the calculated values into notepad++
Search, Replace
Select Search mode âExtendedâ
Find what: /t {tabs}
Replace with: , {commas}
Save As some_filename.param
Apply the new .param file using Mission Planner or similar - I find this quicker and easier than manually finding all the parameters and trying to set them without making mistakes.
Everyone is free to provide feedback, modifications or otherwise.
Iâve simplified and fixed a couple of things in this updated sheet, please download and it try out while I work out how to get it functioning in the Tuning Process Instructions doco.
It looks a little cleaner and I like how you separated out the battery settings from the others. The new suggested settings are appreciated. I noticed that three parameter have been removed from the new spreadsheet:
AUTOTUNE_AGGR
MOT_BAT_CURR_MAX
MOT_BAT_CURR_MAX
I am just curious what was the reason for removing them?
Itâs good to know someone is checking
For those settings the defaults are the correct settings and shouldnât be changed unless you undertake a little further investigation. I was keeping in mind this spreadsheet is for initial setup, and for first-time builds.
Theyâd been included before because I was tweaking them previously and neednât have been in that old spreadsheet.
That spreadsheet is awesome. It matches the hand calc values that I do all the time. What would be super cool is⌠if you could export those vales into a text file that I could use to upload into MP
I really do think there you be a âHow to Setup your Multirotor with APâ sticky that includes this sheet as well as a link to the tuning page.
There seems to be a bunch of folks posting their âI crashedâ or âit just doesât fly rightâ type of threads that never set all the initial tuning parameters before their first flight.
Enter your prop size in inches , and the number of LiPo cells .
Search, Replace
I toyed with the idea of getting the spreadsheet to generate a param file but then you lose cross-platform compatibility, and it gets quite complex.
Itâs already proving difficult to get it working as an âonlineâ interactive sheet or calculator, but I havenât given up yet.
