In this post (below) check the pieces about baud rate. There’s a setting related to WiFi baud rate.
Is just the slow baud rate the only thing holding you back from using the ordinary firmware with RC-passthrough? If so follow the guide to fix everything AND change over to using SBUS instead of PPM.
