I am trying build a vtol minitalon similar as Cuong le plane, but 1250kv for copter and 1000 for plane, because i thing that my quadplane will have a 2.8kg.
With a 10Ah 4SP1 as battery. What flight time do you think i can obtain?
What flight time and setup do you have?
Would anyone on here be able to suggest good VTOL PID values for a mini-talon? Or a good way of tuning them? I saw a PID autotune that looks promising, but it doesnāt appear to be in the 3.9.10 version of the code that Iām running and I donāt see it mentioned in the subsequent release).
I believe my roll PID values are too aggressive and need to be dialed back. They were way off w/o the wings, but itās hover-able now with the wings installed. But I still hear a bit of oscillation at times.
Here is my .param file from August 2019. My mini Talon QP is still flying great this summer! To easily dial back your aggressive Roll PID, lower the RLL2SRV_P value by 0.1 or 0.2 decrements. Mine is currently set to 0.8679144.
I did some mods based on your parameters (as described below), but the parameter you suggested is not part of the VTOL controlā¦itās coupling from roll to aileron servos. That one I can tune with the normal plane auto tune.
For the VTOL controller, I dropped Q_A_RAT_RLL_P to 0.2 from 0.25 to match your value. Did the same for Q_A_RAT_PIT_P. Iām predicting this will help and be a good place to startā¦but let me know if you think Iām off base.
For Q_A_RAT_YAW_P, you have 0.4, but I have 0.18. Did you turn up yaw to make it rotate better?
Yes, you are correct. My mind was in FBWA modeā¦still tired from my trip to Canada.
I think your Q_A_RAT_RLL_P change to 0.2 is a good try. My Q_A_RAT_RLL and Q_A_RAT_PIT settings are the same. I canāt remember what your build looks like.
As for the Q_A_RAT_YAW_P change to 0.4, it was done years ago and I canāt remember why. My yaw control is solid yet still responsive to the sticks. The QuadPlanes can hold themselves better in wind than a tilt-rotor tricopter. Some folks look at QPs as being less efficient but they can handle more adverse conditions so itās a trade-off.
I flew this morning with the changes. Pitch and roll seem better. Yaw is very slow, so Iāll try the higher P value next time around. Motors are nice and cool.
With the longer flight I got some data on current consumption. I havenāt calibrated the 2nd current sensor (where the quad motors are powered), but I got lucky on the battery usage and have a fairly accurate measurement of current used. Iām drawing ~30 Amps @ 6s in hover which seems reasonable. I have 4 T-Motor F40 ProIII motors driving HQProp DP 6x4x3V1SB propellers. Since each motor is capable of doing 30 Amps, Iām only using about 25% of the possible power to hover.
The front left and right rear motors are loafing compared to the other two. Iām guessing that this is to fight yaw, but it seems fairly extreme. In QHover, itās quite noticeable, but in QLoiter the front left motor drops all the way to (what looks like) a minimum value for as long as 4 or 6 seconds at a time.
Could this be because Iām 10-15mm too tail heavy? Hereās a pic of the plane showing the location of the quad motors.
It could either be from CG, wind, or the direction of travel or a combination of these. My motors are not exactly the same either. The first image is in both wind and travel. The second is just travel with very low wind. The design of the mini Talon limited the positioning of the motors so mine are not perfectly around the CG. Remember that hovering is only meant for short periodsā¦the plane mostly flies!
Roger, Im in the tunning process too with F80 motors, my pids are much lower than Greg for this kind of motors but Im still tunning yet, reduce D term too if you have high short wobbles.
My MT quadplane ha been collecting dust for more than one year. Yesterday I updated the firmware to the latest stable one (was at 3.8.5 I believe). I had a test hover today and everything seams to work as it should. Hopefully I can get it out flying again soon
I updated my MT VTOL this summer, and, other than burning out the forward flight motor, it still works fine. It was strangely fun to figure out why the plane was just āsittingā there in FBWA mode during a flight. It finally dawned on me that the Q_ASSIST_SPEED feature had kicked in.
Thanks Greg. I read about your motor failure yesterday. Good thing that the code is mature and robust enough to catch such events
It lives to fly another day
The first 1:09 shows takeoff and transition (transition starts at about the 47 second mark). The next minute of video is fairly useless as plane is too far off (or in the sun) for the phone to record it well. I only did one loop round the field. From 2:15 to the end (at 2:42) shows the descent and landing. The descent is fairly slowā¦at one point I was concerned it was holding altitude with the throttle pulled all the way backā¦but it was descending and eventually made it down. Iām not sure what parameters to adjust, but a faster descent seems wiseā¦30 seconds from 100m down to the ground seemed about twice as long as Iād call reasonable. However, it was a very consistent descent.
Good eyes may notice some misbehavior during the forward transition. I currently have transition set up to occur by turning a 6-position selector switch from QHOVER to FBWA. Those two modes are adjacent on the switch. However, I currently have MANUAL mode one more click over. By mistake, I went from QHOVER to MANUAL (the dial was turned fast enough that the intervening FBWA selection never registered). About 6/10ths of a second later, I realized my mistake and switched into the proper mode (FBWA). The four quad motors shut off about 3/10ths of a second after the mistake and then come back on at a high level after about 3/4 of a second. Bottom line isā¦donāt switch to manual when not flying forward above stall speed! I am now planning to remove manual mode to avoid this possibility in the future.
Those with good eyes may also notice a flashlight (temporarily) taped to the nose . Iām not sure how I managed it, but Iām very tail heavy and needed the weight to get the CG correct. Iām probably going to order a larger battery (currently running a 4000 mAh 6s). I am also planning to add a video camera/VTX and canopy on the nose which will add a bit of weight.
Congratulations on your maiden transition! The flight looked fine and you will gain experience with each flight, making lower transitions back to QHOVER or QSTABILIZE modes. On my VTOLs, I also remove MANUAL mode since QSTABILIZE is my emergency go-to mode.
Many of us (including the non-VTOL FPVers) have heavier cameras with gimbals on the front pod so it is good that you are tail heavy until you figure out your own setup. Mark_Q on RC Groups has designed many 3D printed options for the MT. I use a 4s 8AH pack with a single axis Mobius gimbal and still need to add weight up front.
Using my largest battery pack, I finally managed to get q_autotune to finish on the roll axis for my mini-Talon. I first reduced Q_A_RAT_RLL_P for the roll P term from .20 to .15. After the flight:
Q_A_RAT_RLL_P was almost back to before the change with a value of .1995105.
Q_A_RAT_RLL_I had exactly the same finsihing value as P at .1995105
Q_A_RAT_RLL_D finished at .005194611
I tried to do the pitch axis using a slighltly smaller battery but had to abort before completion.
I found the log data showing the parameters that pitch was moving to. Even though the tune didnāt complete, it was on step 4 (of 4) and the values were reasonable and stable.
So I set
Q_A_RAT_PIT_D to 0.0657
Q_A_RAT_PIT_I to 0.227
Q_A_RAT_PIT_D to 0.227
I noticed oscillations later and backed off a little. Ended up with D at .0557, I and P at .217.
It took a few tries, but I got yaw to autotune as well. These numbers are way different than Gregās.
Yaw appears to not use a āDā term. Itās 0.
Q_A_RAT_YAW_I = 0.1632059
Q_A_RAT_YAW_P = 1.632059
Iām not entirely sure if these are good numbers, but it was flyable and seemed much more responsive.
However, I then encountered a problem while executing a dive in forward flight. In FBWA, I started a dive at about 100 meters and attempted to stop the dive at ~50 meters. The plane would not pull out of the dive and hit the ground at about 40 MPH. Fortunately it was almost level at that point, so damage doesnāt appear extensive and I should be able to test more when the weather settles down.
So sorry for your crash, Im curious why the quad canĀ“t save your plane to be attent when I fly mine, you cant switch to quad modes or the quad cant be able to rescue?
Greg: Thanks for the mixing gain tip. That might help. However, I decided to relocate the tail servos to the fuselage to avoid interference from my RFD900 antennas. So I also need to double check that the remote linkage isnāt allowing unwanted deflection of the control surfaces when under high stress. I think I have sufficient telemetry data to figure it out in time.
Cala2: I have a 3-way safety switch on my TX. Down is manual mode and throttle is forced to zero. Middle is forward flight (currently limited to FBWA). Up is vertical flight, with the selected mode (QHover, QLoiter, QRTL) controlled by a rotary switch.
I should have flipped the switch to quad mode for recovery! But I didnāt. My rotary switch was in QLoiter and switching to QLoiter in the middle of a dive at 50 or so MPH would have been a very abrupt control change. However, n retrospect, it would have been far better than continuing to fight for control in forward flight.
Itās also possible that Manual mode might have allowed more elevator deflection. I didnāt try that one either.
We need more channels to flying modes in planes as it is in copter, I have switches in my radio and can rescue an expensive flying wing when dive, much easier to react during an emergency than rotary switch, Im try to add to github.
