OK. For another $15 you would have that (Omni Nano F4). For another $35 you could have a F7 (Kakute F7 mini) in that form factor. This seems negligible for the $/benefit but I understand everyone has their own budget.
If you have a spare esp8266 you can flash it with this https://github.com/ArduPilot/mavesp8266 to have WiFi telemetry, then enable MAVLink log with LOG_BACKEND_TYPE=2 and obtain logs with MAVProxy and DataFlash Logs module http://ardupilot.github.io/MAVProxy/html/modules/dataflash_logger.html
Maybe a little bit complicated, but I did it some times ago and it worked for me.
Hi⌠I recently installed an Omnibus F4 V6 to an Ori32 ESC. Unfortunately, I cannot get the ESC start the motors. So far, I have detected no shorts and plugging in a lipo to the ESC starts the RX and VTX. The FC shows a solid green light and flashing blue light. However, I get no BLHeli startup sound from the Ori32. I am away from my quad right now but do I first need to open BLHeli suite and have the new FC recognize the Ori32?
No. But after configuring the BLHeli passthrough parameters you may want to connect via BLHeli Suite anyway to see if they are recognized. I have that same combination of FC/ESC.
As a really crude approximation put the copter in a hover and use an iphone app to measure the frequency. Not sure how well this will work, but I have used it to find prop resonant frequencies.
Thanks Andy, i hope find app like this also for android
Thanks Andrea, i will tryed also with this, after want attempt with the dampers
Hey I am very new to drones. I have pixhawk and I am intrested in controlling the drone using RC control. Can anyone please suggest me how to i control the drone using RC control.These are the questions:
Where should the receiver of the RC be connected?
Does the signal of ESC be connected to RC receiver or to the pins of pixhawk?
When 4.0rc2 is out I am happy to do you a version including my FFT changes if you want.
Great! Yes! Thanks!
HI @andyp1per I would like to see if I understand well.
The version you are talking about is usable only with Blheli_32 ESC with telemetry.
In the case of Blheli_s ESC is always possible to use the notch filter analyzing logs as described here https://github.com/ArduPilot/ardupilot_wiki/pull/2072
Am I right?
@anbello Copter 4.0rc1 includes throttle based dynamic harmonic notch support which you configure using the wiki document you reference. Copter 4.0rc2 should include https://github.com/ArduPilot/ardupilot/pull/12544 which if you have ESC telemetry allows you to configure the harmonic notch without needing to do FFTâs - it just works. If you donât have telemetry then https://github.com/ArduPilot/ardupilot/pull/11886 would allow you to do the same thing, but that wonât make it into Copter 4.0. I am suggesting I can do a build of rc2 but include https://github.com/ArduPilot/ardupilot/pull/11886 as well.
Thanks @andyp1per if you point me to a fork with this PR merged I can build it for my copters and test it, but I donât know when I will have the time to report result, I am in a period with next to nothing spare time
This includes all of the rc2 fixes so far + my FFT PR
Thanks @andyp1per, when I will test it I will have to set the parameters as in the first post of you PR https://github.com/ArduPilot/ardupilot/pull/11886 only with INS_HNTCH_MODE=4.
Is it right?
Yes.
The minimum you probably want to configure are something like:
FFT_ENABLE = 1
FFT_MINHZ = 80
FFT_MAXHZ = 350
But the last two will depend on your copter size and motor kv although I think those are reasonable values for most small copters. I also run with a window size of 64 and overlap of 0.75, but that takes more CPU and I have an F7
And for the other INS_HNTCH_* params do I have to leave all default values?
Defaults should be ok. The best thing to do is first enable the FFT but donât enable itâs linkage with the harmonic notch (so leave that as throttle-based). Then hover for a couple of minutes and see what the learned hover frequency and ref values are. If these look reasonable then you can first configure the throttle-based harmonic notch with these and try flying. If that works well then compare the log output for the frequency with the throttle-based output. If all looks reasonable there then switch on the FFT linkage.
Or just set the settings and cross your fingers
Thanks, now is all clear, i think I will go with the âcross your fingersâ option
Iâm sure thatâs fine, the only thing to watch for is dropping the notch too far into your control bandwidth - so for instance if I set MINHZ to 50Hz on my 4" quad it gets very unstable. So higher is safer, but you obviously want to target enough of the throttle range to be useful.
