from this Prerequisites it states that First, make sure that you have successfully installed ROS 2 Humble. so I can scroll down and get the instructions for the ROS 2 on Raspberry Pi
Does anyone know what it means to change to the directory linked above, then to the directory with your preferred variant in Clone the docker_images git repo onto the Raspberry Pi, change to the directory linked above, then to the directory with your preferred variant.
I am hoping the journey will lead me to MAVROS build / setup successfully on Pi4B eventually.
docker is up and running and cloned the docker_images.git
$ docker run hello-world
Hello from Docker!
This message shows that your installation appears to be working correctly.
To generate this message, Docker took the following steps:
- The Docker client contacted the Docker daemon.
- The Docker daemon pulled the āhello-worldā image from the Docker Hub.
(arm32v7) - The Docker daemon created a new container from that image which runs the
executable that produces the output you are currently reading. - The Docker daemon streamed that output to the Docker client, which sent it
to your terminal.
To try something more ambitious, you can run an Ubuntu container with:
$ docker run -it ubuntu bash
Share images, automate workflows, and more with a free Docker ID:
https://hub.docker.com/
For more examples and ideas, visit:
Overview of the get started guide | Docker Docs
$ git clone GitHub - osrf/docker_images: A repository to hold definitions of docker images maintained by OSRF
Cloning into ādocker_imagesāā¦
[Edit]
SD card 1, Debian version: 11 (bullseye) 32-bit + Pi4B, failed attempt
