Is there someone who knows where to find the description of the Hott Telemetry Protocol? Sumd I have found but the telemetry protocol seems to be well hidden to me
I successfully upload v1.4.6 and use it with a GR16 and arducopter 4.0.3 with a Pixhawk 4 mini. I need just to connect the telemetry input (arduino pin3) to the pin 2 of the pixhawk telemetry connector (the 1 is the red +5V).
At the beginning, it was necessary to have the 433 MHz telemetry link established with Qgroundcontrol to get data on Graupner Tx.
After setting following parameters with an USB connection :
SR1_EXTRA1 10
SR1_EXTRA2 10
SR1_EXTRA3 3
SR1_EXT_STAT 2
SR1_POSITION 3
SR1_RAW_SENS 2
SR1_RC_CHAN 2
It works perfectly.
One remark to zdv770
do you plan to publish your code in order to insure its maintenance in case you switch to other hobbies???
Without it, using Graupner Tx for Ardupilot UAV won’t be so easy.
we have v1.4.6 on arduino, Pixhawk with PX4, Graupner MZ32 and everything is working fine while UAV is disarmed. The moment when the drone is armed and motors start spinning the 2times/sec flashing switches to very slow flashing (5sec on, 5sec off) and telemetry values on RC are freezing. When disarming again everything works fine again.
Any ideas?
Thanks
Max
I plan to replace my MX-16 Tx by a MZ-16 to increase number of channels available. But I wish to keep Telemetry as friendly as with my MX-16. Does anybody have MZ-16 telemetry screenshots with MavLink2Hott interface ?
I connected the esc telemetry line that supports hott telemetry to the RX port and set the [SERIAL1_PROTOCOL]to 27 (HOTT),Can read voltage and current information in flight control?
