please write us directly from web chat, we will help
What would you like to specifically see here? when using the mavlink inspector, you end up with a log string of the various parameters that are being streamed at various refresh rates. I donāt really know how to appropriately capture an available bandwidth metric from this view, as you canāt really even copy and paste, so the best i would have is a screenshot of 2-3 of the vehicles data rates. I was able to connect 5 on the net, and am working on a few more.
Chris
What is your Zoon configuration indicated in https://zoon.dronee.aero/ right now?
Did you test the range?
Do your GCS request messages at a specific rate or you leave it vehicle as it performs by SRX_ parameters? So I can guess what your effective payload is and you can say that it actually matches with the configured/requested rates by observing mavlink inspector.
It might also be worth having a glimpse at this https://discuss.px4.io/t/wifi-lora-telemetry-add-on/4860 discussion
Looks to me like an old and dead project⦠hereās what the autor wrote in 2018:
" Sadly the project is a bit on the back burner at the moment. The esp8266 part works, but I have not tested the stm32/lora partā¦"
Well, maybe there is a chance to reanimate this project?
Just an update here, I received 3 units and I am still evaluating on the bench with SITL and different GCS as part of my Blog series on SWARMING.
I will probably write full report after real life testing later (late spring).
@ppoirier, have you had any luck so far? despite testing out the V1, V2, and V3, i havenāt found any of them to really be able to maintain a connection at a long enough range to warrant even trying to do swarming work, as i get GCS failsafes constantly (at less than 200m).
So far just bech testing, it is still snowing here in QuƩbec
Might start tests in a month and I wil certainly update
Much appreciated⦠snow is gone here in Upstate NY, so iām getting antsy again!
Chris,
I recently got some ZOON V3 radios and am having issues connecting multiple vehicles to my GCS⦠I know I must be missing something obvious can you give me a brief explanation of how youāve done it before?
hi Ana,
you have done some range tests of your radios? I have issues even with a single airplane in the air
Alessandro,
I havenāt been able to get the radios to work with connecting to pixhawk now⦠not sure whats happened and havenāt been able to do any flight testing yet. Sorry!
Did you test it? I like this idea tooā¦
Ana,
Be sure to turn off the ismesh field in the configurator, and enable mavlink swarm. I used apm planner for testing on the ground, but the link was so unreliable that I wasnāt willing to try any airborne testing. I used the V1, V2, and BE, and just didnāt get results that even came close to the alternatives on the market.
Chris
Thanks Chris,
Iāll try to turn that off and try again. Considering I canāt even get it to connect to anything other than the online configuration tool I will stick with other products I have for testing.
Are you able to share your code?
It is posted here: GitHub - ktrussell/Serial_to_LoRa: Transmit and receive programs for Arduino Feather M0 LoRa module to transmit one way data over LoRa.
Hi. I am sort of new to the LoRa Technology and donāt know much. I actually wanted to ask how to connect LoRa module to STM32 for making it work as RC transmitter. While on the receiver end I was thinking of connecting ELRS (or should I use LoRa module only?) to the FC in one telem port, whereas to get data on the mission planner I was thinking of connecting normal telemetry device on another telem port and connect it to the laptop. I want to use 2.4 GHz. Is there any other way to do it or am proceeding in correct direction? Just wanted to know that much. Thank you
