as last trial you can try with these options… with mission planner just press Ctrl+F whilr the fc is connected and just choose the option Bootloader update or just try to install qgroundcontrol and try…
I suspect that the bootloader thing is a red herring. It’s more likely that there is a hardware issue that is causing the flight controller to not come up correctly. For example an IMU failure would make it unresponsive.
Hi Randy, i need an info and if its possible an advice, as im still running on my mro x2.1 arm F4 the firmware version nuttx 3.6.9 (im using qgroundcontrol) i need know what will be the emprovements about update the it with chibios version 3.6.9
@Dave84, for most users there is little noticeable difference between NuttX and ChibiOS. ChibiOS runs more quickly and efficiently though so the vehicle does fly slightly better. Also the reduced memory and CPU usage means we will be able to pack more features into the software in coming releases.
Thank you for the info you gave me, i will test it and I will report you.
Hi @rmackay9 Is there any way to confirm it could be a hardware issue? If it is a software issue do you suggest anyway we could tackle it ? We got it from someone else so we want to just confirm its a hardware issue before returning it.
@Dave84 We got the STLINK V2 but I am unsure where the swdio, swclk, gnd and rst pins are on the Pixhawk. I have attached a picture of the our pixhawk board. I have marked the FMU Boot pin and the Debug port as per (http://ardupilot.org/dev/docs/debugging-with-gdb-on-stm32.html) ( http://ardupilot.org/copter/docs/common-pixracer-overview.html#debug-port-jst-sm06b-connector) Could you please help me identify the right pins?
Hi @Dave84 I am unable to connect to the STLink tool. I get these errors.
11:32:59 : Disconnected from device.
11:33:02 : Can not connect to target!
Please select “Connect Under Reset” mode from Target->Settings menu and try again.
If you’re trying to connect to a low frequency application , please select a lower SWD Frequency mode from Target->Settings menu.
11:33:12 : No target connected
11:34:01 : STLink USB communication error
11:34:21 : Can not connect to target!
If you’re trying to connect to an STM32W1xx device, please select Normal or HotPlug mode from Target->Settings menu.
11:34:28 : No target connected
11:35:04 : STLink USB communication error
Do you power the pixhawk while the Stlink is connected?
I power it as soon as I connect the ST link
can you send me pls pictures of the wiring
Hi @Dave84 We don’t have connector heads so we are holding the pins. But this is what our connection looks like.
Black - GND
Brown- 3.3V
White - SWDIO
Grey - SWCLK
@Dave84, We are a little confused about the sequence. Are we supposed to power the drone after we connect the STlink to the board? Also, does the FMU Boot pin need to be pulled up to 3.3V? What order should this happen in?
We first connected the fmu boot pin to 3.3 V then connected the ST link pins , then powered the drone and then clicked on Target> connect on the ST link utility tool. It seemed to have connected once . The time it connected the FMU B/E light was a constant red/amber then we clicked on target> program but the connection was lost after a little while.
We tried to follow the steps from here Bootloader restore
@Dave84 We managed to have connected and flashed the http://firmware.ardupilot.org/Copter/stable-3.6.1/Pixhawk1/arducopter_with_bl.hex
Nothing different happened. The drone still does not play the start up tone and just the power lights come on. On connecting to mission planner it says “Check BRD_TYPE: Failed to upload I/O firmware”
This is the log of the St link utility tool
before flash the firmware, do you have done the full chip erase…, erase all the memory bank 1 and bank 2 and the full memory?
After you flash the firmware in binary just disconnect the stlink, and while press the safety switch power the pixhawk
@Dave84 We just tried that but nothing different happened. Just to confirm, The right firmware to flash is http://firmware.ardupilot.org/Copter/stable-3.6.1/Pixhawk1/arducopter_with_bl.hex right? Or is it pixhawk1_bl.bin?
:before flash the firmware you must do this:on stlink utility: target option select erase chip, erase Bank1 and Bank2, erase sector (in this option just selcet all).
After this just flash the pixhawk1_bl.bin, you can use also the .hex but try first the binary.
@Dave84 We tried the arducopter_with_bl.hex , it dint work with that. And the ST link utility tool is not accepting the pixhawk1_bl.bin. We are trying the pixhawk1_bl.hex just to see if that works.
@Dave84 We erased everything and were able to flash the pixhawk1_bl.bin. We then put in the Arducopter V3.5.7 Quad firmware from Mission planner. But it’s still giving us the same errors “Check BRD_TYPE: Failed to upload I/O firmware” unfortunately. It may just be a hardware issue as @rmackay9 mentioned . We are just going to send it back. Thank you so much for your help. We learnt alot. We have another iris+ coming in. Hopefully that works good.
