My hexacopter is running on 2 batteries. the first on has high capacity with low C rate and the other on has small capacity with high C rate.
when the drone need high current, which the big one cant suppy, the other one gives it.
that causes a wired sitiation. the voltage is rising after the climbing is done.
the problem is with the failsafe.
the voltage is getting below the low/ critical , the drone enters FS mode, I take control and override the failsafe.
later in the flight the battery will be drained, the drone will not enter FS and destroy the battery in the air
I don’t want to change the low/critical battery values.
Is there a way as in GCS/ RC failsafe that the FS will be “cleared” so next time, it will enter FS again ? Thanks!!
