does the new release of copter 4.0.8 solve this issue of attitude target? @Leonardthall
We are on 4.1 now and I donāt know. Let me know if it fixes it.
looks like typemask 128 still doesnāt work
Oh, sorry. You are talking about the set attitude target.
https://mavlink.io/en/messages/common.html#SET_ATTITUDE_TARGET
Did you check my PR?
Yes, I used your PR, I am having one issue with it. actually, I am using mavros_controllers which publish the body rate on mavros/setpint_raw/attitude, It works fine with PX4 autopilot, but when I am trying to see the same with ardupilot, the UAV does random motion and crashes
Do you have a log?
It looked like it worked properly when I tested it.
when I publish arbitrary bodyrates in either x or y or z axis, the UAV moves the respective axes in case of PX4 and your PR so I donāt think thereās some issue related to the Axes
Do you have the specific message being sent?
as in? Do you want to see a sample message?
I have not put in the rate logging on the input. If I added that now how long would it take you to test it.
If you have a specific message I can test. When I tested it I did it by doing loops and rolls and yaw rotations. Maybe I missed something in my test.
actually i donāt have a specific message, I am trying to test a path planner along with mavros_controllers so it constantly publishes on that topic, I can test it right now if you pust the changes to the PR
Ok, I am checking it quickly now.
Give me a sec
I just pushed two commits to the PR.
I will test them here but this way you can get started at your end.
Okay, Iāll test the PR, just a request, if possible please test the PR with the repo I mentioned above, so that we can make common conclusions and it will help me a lot
thanks for all the support
Make sure you set:
GUID_OPTIONS 8 to get the proper interpretation of that message!
where can I set this? as a message parameter?
In the arducopter parameters.
okay, thanks, will do
