I just tested it again and it all worked:
can you please test it with the repo i mentioned? and where can i set GUID_OPTIONS 8, since I am not using any GCS, how can I set this param in SITL
Sorry but you will have to test your repo. I can only test my code.
you can set parameters:
https://ardupilot.org/dev/docs/using-sitl-for-ardupilot-testing.html#setting-parameters
okay thanks for all the info, Iāll post the results of testing
You have to load the module first
module load message
If you want it to continue to move you need to ignore the attitude too.
So type:
module load message
Then
message SET_ATTITUDE_TARGET 0 1 0 128 [1,0,0,0] 0 0 3.14 0.5
okay thanks, Iāll try it
Any luck. I am about to go to bed.
No, I used all the above info and tried running the path planner with the mavros controllers but still it is exhibiting same behaviour
Just for perspective, when mavros controllers publish body rates, it works as intended with PX4, autopilot
Any suggestions on how can I debug this problem?
Do you have the log for me.
Did the direct command work for you?
Hang on, are you saying you do get the correct response when you command normal body rate commands. But it is only when you run your whole script that it causes a problem?
I did that test just to make sure that my copter is having the same frame of reference in both the cases
I will run the path planner stack again and Iāll share the logs
one of the sample message being published on the topic
header:
seq: 1232
stamp:
secs: 506
nsecs: 966000000
frame_id: āmapā
type_mask: 128
orientation:
x: -0.00979128452178
y: 0.00281856491637
z: -2.7598803652e-05
w: 0.999948091492
body_rate:
x: 0.143888078962
y: 0.0323702044223
z: -0.145392262634
thrust: 0.0
So in the log
So as far as I can see you have taken off in guided mode and immediately commanded a roll and pitch rate of 1.3 degrees per second and a yaw rate of 572 degrees per second (crazy high) and a throttle of 64%.
I can see that the aircraft commanded attitude is following the guided command. However the aircraft flips on take off.
Is this running the models in SITL or is it connected to some other flight model. The reason I ask is the logs look like the simulated aircraft is not stable or has not been setup properly. This may simple be because the guided inputs are crazy and the aircraft doesnāt get a chance to take off and basically flipps immediately OR it may be because you are running a different flight model that doesnāt match the autopilot setup.
In general here mate I think this is your code not ArduCopter. There is not take off command and you are immediately commanding a huge yaw input before the aircraft can take off. I can see the targets are following the guided inputs. I can see that the Guided inputs are crazy and the aircraft hasnāt been given a chance to take off.
Please donāt mention PX4 again. I donāt care what PX4 does or does not do and it isnāt relevant here. I have logs that show what you are commanding is crazy and the aircraft canāt follow these commands for some reason. The question is why.
If you want any more of my help you need to make more of an effort to answer my questions clearly.
Did you manually command body rate commands using guided mode like this?
module load message
And did it yaw at 180 degrees per second as you would expect?
I suspect your code is the problem here. To convince me there is a problem with the PR you will need to take off properly using either a take off command or manually, then start your script using requested rates that are sensible.
Hi, Thanks for all the insights, when I manually commanded the message you mentioned, in logs, I can see there is a mismatch in desired pitch roll and attained pitch roll, I will try your suggestion of starting the script after manually taking it off below I have attached the log file when I used the message command manually
thanks logs
It doesnāt look like you attached the log.
