Please forgive my newbie question, but I’m experiencing trouble on what appears to be a Python related installation issue. Can someone tell me how to handle this error output during MethodicConfiguratorWinBuild…
C:\Windows>python.exe -m pip install . --user
ERROR: Directory ‘.’ is not installable. Neither ‘setup.py’ nor ‘pyproject.toml’ found.
Thanks @amilcarlucas and the other contributors for this excellent guide.
Just a little side note:
Meanwhile there is an “Ultralight” version of that Helical H-RTK F9P available, that will save some significant amount of weight for such a small build.
Can someone give me a hand?I’m dealing with a problem.
VTOL-expo.lua failed
use cuav pixhawk v6x flight control,firmware version arducopter 4.5.1
GCS message
2024/4/26 17:35:29 : Throttle disarmed
2024/4/26 17:35:25 : RC6: MotorEStop HIGH
2024/4/26 17:35:05 : tempt to call a nil value (method ‘get_accel_ef’)
2024/4/26 17:35:05 : Internal Error: /APM/scripts/VTOL-expo.lua:188: at
2024/4/26 17:35:04 : Throttle armed
2024/4/26 17:34:59 : Expo: Must be flying to tune
I am using speedybeef405mini, which is included in firmware limitation . I tried temperature calibration but i don’t find INS_TCALn_enable parameter. latest firmware 4.5.2.
Really complete post, I’m in the tuning of my now quad project, very happy to find this!
However, I run a custom arducopter firmware on a betafpv AIO board that has no sd card.
How can I complete the IMU temperature calibration without it? Could I use the .bin log downloaded via mavlink? If so, should I download the latest log directly after the completion of the calibration, before powering off?
I have to say a feel a bit stupid having spent so much time on it…
Finally I found the bug, just my custom build of Arducopter that has no IMU tmp calibration available.
As I fighted to obtain a build that fit in the board and disabled the maximum of items, I missed that option. When I realized the mistake, I tried to build the same version but with IMU compensation, and it was oversized for the board. I had to switch to 4.4 to obtain a firmware that fit.
The good new is that we have a very performing 2.5 inches whoop for all piloting skils, running 15 minutes (max) under custom 2S Li-ion battery, with MTF-01 optical flow and Rangefinder, with HD Vtx (walksnail or HDzero)
We stil did not made the whole protocol of tuning, I’ll keep yu in touch!
I’m not good at English, so I’ll start by saying that I use Google Translate.
The aircraft weighs over 40kg and I’m using four X11Plus.
I used the x11plus template right away, and proceeded to the setup of the harmonic notch filter before flying.
I flew with ALTHOLD, but it reacted strongly to the throttle stick, and I couldn’t control it, so I forced it to land.
I thought there might be a problem with the parameters, so I reset it to the default parameters, set it up again, and flew, but it reacted excessively to the throttle again.
Please tell me which part I should check.
I apologize for omitting the temperature calibration.
