RC_OPTIONS, 288 is used for telemetry passthrough over CRSF for the Yaapu telemetry script on the Radiomaster TX16S (no connection to Mission Planner at this point).
SERIAL2 was connected to the Crossfire Nano RX pins 3 & 4 for MAVLink over CRSF, where the PC with Mission Planner is connected via wifi to the Crossfire Micro TX. However that didn’t work for us in the end because of strict firewall settings (company laptop).
I had PID checked. I don’t see a RATE item to check in the bitmask. I was using the logging bitmask from this tuning process. (LOG_BITMASK = 145372)
Is RATE part of “Fast Attitude” maybe? Thanks.
@KevinB Section8 of the document above has details about that.
And you can also plot the PID?, RATE objects in the .bin log files and compare them with the RCIN objects.
The configuration uses different LOG_BITMASK values depending on which configuration step you are currently doing.
So if for example the LOG_BITMASK for the Notch filter evaluation is wrong, you just need to fix it on the vehicle_examples/diatone_taycan_mxc/4.5.1-params/13_logging.param file
But today we tuned another same size drone and we couldn’t save prams when we used the configuratior maybe some issue from my end must be missing out on something maybe.
But we tuned using the above guide. And tuned it completely ( wihtout wind compensation and motor calibration ) and it was just much easier this time and quicker.
Also had to disable current and volt sensor because of wrong reading I hope that won’t affect tuning and magfit ?
@rmackay9 for the impatient users I now added a path to jump from section 3.2 into section 12 skipping the optimization steps in between and trading-off complexity and comprehension with simplicity and speed.
I also added a quicktune step at the end of section 3.2 to reduce the risk of the second (MAGFit) flight.
Please forgive my newbie question, but I’m experiencing trouble on what appears to be a Python related installation issue. Can someone tell me how to handle this error output during MethodicConfiguratorWinBuild…
C:\Windows>python.exe -m pip install . --user
ERROR: Directory ‘.’ is not installable. Neither ‘setup.py’ nor ‘pyproject.toml’ found.
Thanks @amilcarlucas and the other contributors for this excellent guide.
Just a little side note:
Meanwhile there is an “Ultralight” version of that Helical H-RTK F9P available, that will save some significant amount of weight for such a small build.
