i connect a usb serial to the FMU Debug Port, but i can not get any message.
how to get the debug message, for example the hal.console->printf() , where i can get the output message ?
If you need to use stlink to flash a bootloader or run a debugger on startup, you can use the swdio and swclk.
The uart can be assigned via a param to whatever you like (sensor, mavlink, sbus etc).
