GSoC 2024: High Altitude Non-GPS Navigation
Ya we continue here only. Really great to know that it’s working for you. If you can share a log and the video, it would be really interesting to analyze it.
  1. I don’t have results from real life, but if you are using a powerful companion computer, I am using position correction based on loop closure to correct the drift. It’s still in development as sometimes there are false positives and it can worsen the results.
  2. They all serve the similar purpose. Other methods haven’t been merged and tested intensively yet. So I resorted to this one. Also position estimate is a bit delayed in my case, and hence I used MAV_CMD_EXTERNAL_POSITION_ESTIMATE.
  3. Yes IMU improved the system. IMU data is back tracked to correct drift and dead reckoned for a very small fraction of time to compensate for processing time.
I am currently trying two different methods right now:
  1. Which doesn’t require pre-processed dataset of images
  2. Which needs satellite image or orthophoto of the area.
Also, I have posted an update here: GSoC 2024 wrapping up: High Altitude Non-GPS Navigation - #10 by snktshrma
