Hello,all.
We tried autonomous flight using raspberrypi and dronekit. The sequence is written below (now we do not attach propellers).
Change to stabilize mode, armed, change to loiter mode, take off, hovering, change to guided mode, and land after my quad arrived at our goal.
When we remove ‘change to loiter mode’, the sequence works well.
What is the our problem? What we should do?
Please teach me.
Hi @NK_AA! Are there any messages popping up on mission planner? Logs would really help in identifying the issue. You can try turning on log_disarmed parameter and try making a small log file where you try to switch to Loiter mode.
@NK_AA It’s a possibility that GPS HDOP is high and both, loiter and guided, needs HDOP lower than 2. But ya as soon as you send the log, it’ll be more clear.
For security reasons at my current location, I cannot send the entire file.
What information should I send you?
I think that pos_horiz_abs Off in EKF Staus Flags has something to do with this problem.
I have the same problem, the error I see is “Prearm: Need position estimate”, I read different solutions but I have no answer since I have done everything they tell me but without a good result, in the EKF it shows me the same error which is “pos_horiz_abs Off”, do you know how I can solve it? I also manage in GUIDED mode
