For non CRSF users here’s another lesson I learned today:
When you upgrade to EdgeTX2.8 and Yaapu 2.0 you will also need to update your multi-protocol module. I updated a radio that had an older firmware on the multi-protocol module and there was no telemetry data on FrSky D16 drones. Once I updated the 4-in-1 module to 1.3.3.20 the telemetry worked again.
Indeed, the price you pay for bleeding edge is the pain associated with updates. I love ExpressLRS and am unlikely to use any other protocol anytime soon. But I’m keenly aware of the hassle required if/when I choose to update RC firmware.
Problem solved! I did not realized that EdgeTx screen has scroll down has multiple Yaapu Debug lua scripts. I was pressing Yaapu Debug, when I should have scroll down to the Yaapu Debug CRSF.
Typical user error.
When I switch models the Yaapu script seems to stall. I get the message that it’s “ready” but the screen gets stuck on “initializing”. The only way to clear the issue is if I power cycle the radio. Once it’s running however there doesn’t seem to be an issue. I’ve also tried to reset the flight and all the timers, but no luck.
I have upgraded from 2.6.0 to 2.8.0 edgetx and six of my sensor coming from passthrough freezes randomly
VFAS ARM GALT THR etc freeze down even with new 2.8.0 stable edge tx…i dont have this problem with 2.6 or 2.7
Previously reported issue
Setup:
Tx16s mk2 + TBS crossfire 6.19
Arduplane 4.4 dev /Matek fc f405 wing
Yaapu lua also installed 1.96 dev version with crsf enabled
Im using yaapu script (2.0.0beta2 dev)with tx16s on Edge Tx 2.8.0. I ve experinced that the script sometines stuck in the initialization. I had to go into widget setup to start it loading.
FW arduplane 4.4 dev
Found this post about similar issue here: Yaapu telemetry repeat initialization
I’m using Radiomaster TX16s running EdgeTX 2.8.1 . I want to run yaapu telemetry scripts but when I try to do it , I get this. Some of the screen didn’t show any image at all. Can somebody help me with this?
