Hey friends! I’d like to use Wraith32 35a v2 ESC on my 18" quad. In my previous tests I draw about 60a total on full throttle, so I thought they’d be plenty. When I test hovered it, it started with a yaw shake that you can see in the vibrations. I went to land immediately but a single ESC popped before I could get it down. Everything went super smooth in the motor test. Any ideas what’s up? Any help is much appreciated!
I think the problem is in combination of 30V MOSFET`s (QN3109), 6S battery and low-Kv motors. In situation with static thrust (on stand) all works perfect, but when you try sharp acceleration- deceleration commands, voltage spikes may be very high. I have registered spikes up to 36V using 35A Bumpbee-s and 300 Kv motor until magic smoke came down. Adding additional low-ESR caps and maybe TVS diodes should solve the problem, but further testing needed.
How long the wires are between the battery and ESC? Inductance in the leads from the battery to the ESC might cause voltage spikes that can kill an ESC.
I wouldn’t fly any of these modern ESCs without an electrolytic cap added on the inputs.
Alex, can you point me to a 3109 datasheet, pls ?
I’ve got the 50A Wraith_32 Plus with 400kV, 15 inch and 6S, with 1000uF caps added, and they work smooth and are just slightly warm to the touch after a flight.
The voltage peaks are still high. These spikes make large changes in voltage potential between ESCs and flight controller. I’m worried about the processor pins on dshot and telemetry link.
Next weekend I will try to add an electrolytic capacitor and/or a TVS diode.
I also plan to measure the voltage drops/spikes on the groud cable (blue line) as a simulation of the cable length between ESC and PDB. This voltage will be reflected on the PWM and Telemetry lines.
Glad to see this once again. You made it very clear with the scope, thanks! (although keeping the scale the same for each measurement would make for a more intuative picture)
The only reason the small race-quads can survive with the original smd caps is because of the very short wires + small motor (despite the large current) and very high C-rated battery’s. If you change one of these things you need to add a capacitor imo. (it’s never a bad thing to add one)
