At a glance, I don’t see an existing Lua binding for wheel encoder data. I’m sure I could figure out how to write one, but that would mean you’d be stuck with my fork/branch of ArduPilot (at least until that binding is merged with the master branch).
@iampete, is there a better/existing way to access wheel encoder data via Lua?
Technically you can read a serial/telemetry port within Lua, but I don’t know of a way to parse the data effectively to capture a specific message without writing a MAVLink library in Lua, which seems like the hard way to do things here.
it s unlucky that the developers of Ardurover are not provided for this display because we can display the speed but not the distance traveled (odometry) while this can be read by the Mavlink, to be sent back to the Arupilot developers for the next update day maybe?
Since I had that lap as mission waypoints, adding the individual distances between waypoints (haversine’s), when the sum was coincident with WENC.Dist’s, and appeared as above, everything was right.
Note above that inner wheel shows a smaller distance.
To be fair, the value is provided via MAVLink, and it can be displayed in the Inspector that Mission Planner provides.
Your request was to display it on two other platforms not developed or maintained by ArduPilot, so the Lua solution seemed most advantageous. However, there is no binding (at present) for WENC data in Lua.
yes indeed I had mentioned two platforms which are QGC and SOLEX in case someone has a solution with these 2 there.
if I understood correctly we can “visualize” but not display the distance in MP as we can do with the speed then? that’s it ?
thanks Webillo
for what : the Rover must move without GPS and I must be able to see how far from the start I stopped to inspect detect objects at the same time.
You only need the rover to move between known GPS points, so you can compare with haversines the WENC.Dist’s on the log. But, for example if you move between two points with distance measured with a metric tape you would not need GPS at all (compare WENC.Dist’s to a known measure).
I think I explained myself badly:
I want to be able to display the distance from my starting point while I am driving the rover.
the goal being to inspect caves and identify objects.
I pilot manually and not automatically, I watch the video from the camera in streaming and at the same time the odometry is displayed on my radio screen.
yes i saw that in Quick Tab and i can display in Hud but only speed is ok the others (distance driven and distance from home) are always on 0.00, nothing move
Try right clicking on the map in Mission Planner and using the “set home here” feature. It doesn’t really matter where you set the home position if you aren’t using GPS, but having it defined may help display the values you’re after.
ok for me, but i have to set EKF origin in MP not home (right click on map and “Set here EKF origin”) it s the best thing because when i desarm vehicule Zero is setting distance ground.
