Dev Call Aug 27, 2018 2300 UTC
Issues & Pull Requests
DroneCore
  • Update
Redundancy
Scripting
Plane
Copter
Rover Boat
  • Sailboat
Attendee count (max): 22
UTC2305 - https://github.com/ArduPilot/ardupilot/pull/9298
  • Behaviour change for loiter mode for tradheli
  • When disarmed or inflight or autorotation using motor interlock disabled
  • Allow pilot to get manual control from loiter mode
  • Navigation controller active as aircraft spooling down
  • Behaviour changes coming in 3.7 to do with spool states
  • These are smaller changes for 3.6
  • Interlock disabled and aircraft disarmed sets position to current position of aircraft
  • Wasnā€™t this supposed to be handed by the donā€™t-navigate-near-ground?
    • Might have been broken
    • Soften-for-landing?
    • Land-complete-maybe is a slightly easier thing to achieve
  • Backportable to 3.5?
    • Probably
    • 3.6 is close
  • merged!
UTC2314 - https://github.com/ArduPilot/ardupilot/issues/9266
  • Random intermittent faults with safety switch
  • Brd_safety_mask parameter when it should be allowing channels it is not
  • Tlog required
  • When you reboot it sets safety on when you reboot
    • Communication with iomcu may not be reliable after it reboots
  • MdB: Nates I think is because we donā€™t have a mixerā€¦
  • Safety mask is a mixer feature and we donā€™t do mixers on ChibiOS?
    • No, itā€™s not a mixer feature
    • Controlled by the FMU, not by rc on IO
    • Shouldnā€™t need mixer
    • [9:18 AM] To Weekly devcall: Also, if itā€™s an intermittent failure itā€™s not a good theory?
  • Tridge has to concentrate on OBC stuff
  • Two incidents
    • Reboot-in-flight issue meant he didnā€™t have control
    • On reboot no surface control
    • Works on NuttX
      • No px4io mixer support in ChibiOS
    • MdB: also kinda curious how it rebooted IE electrical things probably take out IO processor anyways
    • [9:21 AM] (Channel) MdB: So you still wouldnt have servosā€¦
    • [9:21 AM] (Channel) MdB: (until we got far enough in the cycle)
  • Rebooting in flight isnā€™t really supported
  • Doing the mixers is on the todo list
  • Need to find a mechanism for reproducing the intermittent one
    • Or at least a pattern
UTC2314 - https://github.com/ArduPilot/ardupilot/issues/9256
  • Meant to be NFC
  • Grew a bit of FC
  • Reduce code duplication and calls to _start_cmd
  • Fixes outstanding bug where weā€™d get into an infinite loop
    • Set-current-cmd and lots of do-cmds
  • Fixes mission restart related to jump-to-landing
    • You will get naks if you mavlink set-cmd to do-cmds that donā€™t have a nav after them
  • Removes code duplication
    • Removed code didnā€™t have the protections in it
  • Lots of SITL testing done
  • Cleanup prefacing more work to come
  • Should we be using 0 as a flag value here?
  • [9:29 AM] To Weekly devcall: I considered suggesting adding a parameter to indicate whether you should use the index - but decided what MdB had was as good.
  • Tridge is going to do some testing
    • [later] merged!
UTC2331 - https://github.com/ArduPilot/ardupilot/pull/9243
  • 3 questions.
  • Use godbolt to test the std::swap
  • Not being pure-virtual is OK (already the case in HAL)
  • MdB: we do have a bswap set of helpers already as well for swapping (all defer to builtin though)
    • libraries/AP_Common/missing/byteswap.h
  • No screams of pain, we can move on!
UTC2334 - stick-mixing and rudder
  • https://github.com/ArduPilot/ardupilot/pull/9221
  • Adds extra version of plane flight options to only do mixing in manual stabilize or acro
  • Removes caching of input
  • Doesnā€™t change default behaviour
  • Makes no-stick-mixing mean exactly that
  • Diff makes things a little non-obvious
  • merged!
UTC2340 - https://github.com/ArduPilot/ardupilot/issues/9218
  • Relative to what?
    • I.e. cumulative or not?
  • Randy thinks it should be relative to baseline
  • Tridge thinks it should be relative to current speed
  • Would be based on target airspeed
  • Add an enumeration value?
  • Lost-packet problem
  • Peter to do a PR for discussion based on it being a non-cumulative value
UTC2354 - math float-equals https://github.com/ArduPilot/ardupilot/pull/9196
  • No objections
  • Merged
UTC2355 - uavcan refactor
UTC2358 - https://github.com/ArduPilot/ardupilot/pull/8690
  • Frsky telem
    • IMU Temperature
  • Was too complicated last week
  • Brought out a variable
  • Still too complicated
  • Could fix it ourselves
  • Too many ternary operators
  • Has a merge commit in it
  • Needs a squash and rebase
UTC2358 - https://github.com/ArduPilot/ardupilot/pull/8397
  • Tridge couldnā€™t fault this
  • Nateā€™s not on call
  • Needs a rebase
UTC0002 - DroneCore update, Peter
  • Similar to DroneKit
  • Tested. Required some changes, present in Peterā€™s branch
  • Required two PRs:
UTC0010 - redundancy
UTC0012 - streaming updates
UTC0016 - Plane refactoring
  • Want to get Tomā€™s stuff in
  • Both Randy and tridge are keen
UTC0016 - Plane update
  • Log download will be faster on USB in latest beta
  • 3.9.1 will go out shortly
  • Safety fix in in last week
    • Reboot causing vehicle movement
    • Trim settings
  • More test flights required
  • 3.9.2 in next few weeks
    • More boards
      • Hwdef.dat gives some surety
  • Three new boards in last week
    • Drotek p3 pro, speedy, ?
  • S0up active ATM
  • Rescue mode in betaflight?
    • Rtl mode in Copter without a compass
    • Yaw determination without compass
    • Creates fly-forward assumption
      • Kind of like drift mode
  • Outstanding bug
    • Only boot on battery power and not on USB?
    • Tridge spent some time chasing it yesterday
    • Bootloader issue?
UTC0023 - Copter - new rc out soon
  • Reasonably close to 3.6 official release
    • Few weeks
  • Tower issue
    • 3dr usb id problem
    • Forcing usb strings in hwdef.dat makes it work
  • Need to check if rc calibration is working on USB
    • RC_CHANNELS_RAW vs RC_CHANNELS
    • Mavlink2 vs mavlink1
    • Probably MP is looking for the wrong one
  • PR for fixing twitch related to new loiter code
UTC0028 - Rover
  • Sailing code fits OK so far
    • No tacking so far
    • Coming along well
    • Interesting discussion and papers going on
    • Iampete
    • Need to incorporate roll
    • As much sheet on while remaining level
    • Airflow over sail
    • Windvane support coming
    • Randy to test in next week
  • Efforts continue on getting non-gps navigation using lidar and ROS
  • Hectorslam does a terrible job on a bumpy surface
    • Replace with googleā€™s cartographer?
  • Obstacle-distance message support coming
UTC0043 - CAN testing with Nate
  • Will try to look at it tonight
UTC0043 - quick PR to go in to fix builds
UTC0044 - CI and caching issues
  • Both systems have problems
  • OK ATM
UTC0046 - funding update
  • Partner-sign-up for August is looking good!
  • Three others
    • Thanks to Hex!
  • Over 40 partners at the moment?!
  • Tridgeā€™s Believer arrived
  • Tomā€™s arrived
  • Paulā€™s was damaged
    • Will try to get a replacement wing
  • Randyā€™s volunteered to write the Wiki page
UTC0050 - contribution of the month
  • Not merged yet
  • Tridge is considering nominating s0up for board ports
Thanks to Conor and others for help on the notes this week - Peter
