Dev Call Apr 22 2019 2300 UTC
Issues & Pull Requests
GSOC
Plane
  • update on watchdog code (including in-flight reboot successful test on a plane)
11:22 PM
nice
Copter
Rover
Attendee count (max): 22
UTC2302 - https://github.com/ArduPilot/ardupilot/pull/11120
  • Sending jump information to GCS
  • Should we be sending so much text to the GCS?
  • Two good reasons for it
    • Currently no way to track jumps
      • Has confused users before
      • Jump counts of zero
    • Should include mission item count ‘though
  • [9:06 AM] (Channel) MdB: I hate status texts, but this is the only insight, which is fairly relevant for state tracking…
  • [9:06 AM] (Channel) MdB: avoiding #'s in the string would be good though
  • [9:06 AM] To Weekly devcall: As in literal hashes?
  • AndrewTridgell: Jump 17 4/-1
  • [9:07 AM] To Weekly devcall: s/-1/Inf/?
  • Only call into this if we actually do the jump
  • Need to do it all the time, even if we’re not going to take the jump
  • [9:10 AM] (Channel) AndrewTridgell: Jump to 17 (4 of 5)
  • Other conditional jumps should include details
UTC2308 - https://github.com/ArduPilot/ardupilot/pull/11102
  • Tridge hasn’t had a chance to look at this yet
  • Qacro with rate mode wasn’t setting pitch/roll values for logging
  • Minimal patch to set from multicopter controller
  • This also does qstab
  • Rate mode stab is done in qacro so it calls stabilize methods
  • AttitudeControl routine being modified should only be being called by QuadPlane
    • Should be comment there saying that
  • There’s various other methods in AC_AttitudeControl which are QuadPlane-only
  • merged!
UTC2316 - https://github.com/ArduPilot/ardupilot/pull/11099 and https://github.com/ArduPilot/ardupilot/pull/11062
  • Merged - but the other didn’t rebase cleany; Pierre should rebase and check everything went in
UTC2322 - https://github.com/ArduPilot/ardupilot/pull/11095
  • Killed this as it should be floats anyway
UTC2328 - https://github.com/ArduPilot/ardupilot/pull/11094
  • Ccache disabled?
  • Maybe do a ccache -C as last part of the run?
  • Are we going to move the gcc forward from 4.9?
    • Next stable of Copter and Plane so we’re off NuttX
UTC2335 - https://github.com/ArduPilot/ardupilot/pull/11092
  • Template patch was removed
  • Merged
UTC2336 - rangefinder prearm checks
UTC2337 - https://github.com/ArduPilot/ardupilot/pull/11062
  • Already addresses
UTC2337 - https://github.com/ArduPilot/ardupilot/pull/11059
  • Restore plane throttle min behaviour
  • merged!
UTC2339 - https://github.com/ArduPilot/ardupilot/pull/11053
  • Merged!
UTC2341 - https://github.com/ArduPilot/ardupilot/pull/11002
  • Merged!
UTC2343 - https://github.com/ArduPilot/ardupilot/pull/10996
  • Plane: qstabilize throttle midpoint and expo
  • merged!
UTC2346 - https://github.com/ArduPilot/ardupilot/pull/10952
  • Only save gains when landed in autotune for quadplane
  • Minor cleanup for functions suggested by Randy
  • Save-gains-using-a-switch?
  • autotune wasn’t always a flightmode
  • What happened to saving gains with a switch?
  • If you take off again in autotune it will use the new gains
  • Going low-high on the switch should use new gains?!
    • We should test this again
    • Will raise an issue
  • landing/disarming when doing single axes?
    • How does it interact with flicking RC channel option?
UTC2351 - https://github.com/ArduPilot/ardupilot/pull/10941
  • Peter gave a bad method name - will need to be changed
  • Should we make it take a uint8_t?
    • There’s the signed/unsigned char issue
  • Check error return values are consistent
  • Maybe return a bool and a reference to return value?
UTC0002 - https://github.com/ArduPilot/ardupilot/pull/10900
  • Bugs fixed and tested
  • Flag in sim aircraft to give kinematic consistence
UTC0006 - https://github.com/ArduPilot/ardupilot/pull/10515
  • Rebased and pushed up
  • Looks like a good fix from MdB
UTC0011 - https://github.com/ArduPilot/ardupilot/pull/10443
  • Tridge doesn’t like having a single mode.h file
  • Neither does Peter
  • Massive number of files
    • As in an extra 24 files in Copter
  • Does this clean up really help?
  • Need to slow down the rate of change for stable releases
UTC0020 - https://github.com/ArduPilot/ardupilot/pull/10205
  • Added a failsafe for moving channel values
  • Tridge adding a comment and closing
UTC0023 - https://github.com/ArduPilot/ardupilot/pull/10151
  • Not rebased
  • Files are going away
  • MdB is unhappy with scripting modifications
UTC0025 - https://github.com/ArduPilot/ardupilot/pull/10053
  • Randy will try to test this
  • Probably a mission item ordering problem
    • Do vs nav
UTC0026 - https://github.com/ArduPilot/ardupilot/pull/9549
  • don’t publish frozen compass data
  • Requires 30milligauss of noise from compass
    • If you have a really good quality compass it will be marked unhealthy
    • E.g. arming and taking off with really good compass could become a problem
  • If there’s a particular compass that exhibits the problem we should look at why it is happening
  • Are we checking return values in qmc driver?
  • Maybe this has already been solved by one of tridge’s patches? (see issue)
  • Closed this
UTC0031 - https://github.com/ArduPilot/ardupilot/pull/8537
  • Respect condition yaw during landing
  • Assigned to Randy
    • merged!
  • Replaces an old one from Jon
UTC0033 - https://github.com/ArduPilot/ardupilot/pull/8014
  • fix TECS true airspeed rate
  • Do we want the filter on the true airspeed rate demand?
    • If we get a massive spike with this filter then effects will last forever
  • Can probably be closed
  • Tridge will think about it
    • With a comment to reopen if the LPF is thought to be needed
UTC0038 - https://github.com/ArduPilot/ardupilot/pull/6402
  • Peter’s brain left out to lunch
  • Will need to get back to this
UTC0044 - baro vs gps checks
  • Use an atmosphere model
  • Need some hysteresis?
  • Should we mark a baro as bad if we seem really bad temperatures?
  • People could arm at very low pressures and high alts
  • Should check temperatures one against the other
UTC0049 - GSoC update
  • Asked for 5 slots
UTC0050 - notch filters not working?
UTC0051 - Plane update
  • New stable release
  • Stm32 watchdog timer
  • Plane 3.9.8 release
  • IOMCU processor
    • Can’t change protocol because of NuttX support ATM
    • Silly protocol
    • Does correctly reset safety state etc and updates mixer and gives a flyable Plane
    • Setting default rate to servos is broken
      • Probably still have a flyable plane
      • But we can do better
  • CAN timeout needs work
  • Watchdog stuff is in master
  • Ongoing discussion as to when Copter will get it
    • Definitive logging of watchdog event is the good bit
    • Distinguishing brown-out vs CPU-lockup is the tricky bit
  • Septentrino GPS patch will go into next beta
  • Tested lockup in flight - in flight
    • Can restore altitude and attitude and rearm it after an in-flight lockup
    • [10:58 AM] (Channel) LV: armed with right rudder stick ???
    • [10:59 AM] To Weekly devcall: @Luis: yep!
    • [10:59 AM] (Channel) LV: so plane flew right because of the arming procedure ?
    • [10:59 AM] To Weekly devcall: Yep. But I rolled it left a little :wink:
  • The mavlink command - should we have this?
  • Should we tight-loop?
  • We tried it on a Copter too
    • Not so good
    • Would have needed to be at 150 or 160 metres
    • Heli would work
UTC0101 - Copter update
  • https://github.com/ArduPilot/ardupilot/issues/9498
  • Randy’s been looking through the issues a little
  • Funny report from Marco this-morning on an unexplained crash
  • Falling a little behind Plane on releases
  • Almost ready to start beta testing on next Copter stable
UTC0102 - Rover update
UTC0104 - Randy has a RealSense
  • Randy’s hoping to get stuff documented on non-GPS navigation
  • And some work on object avoidance
  • Jaime’s also been working on this
  • 10Hz shaking bad
  • Pointing at corners bad
UTC0105 - Roadmap published
UTC0107 - End
