the flight controller only has one storage place for terrain data. either it be srtm or geotiff. as the flight controller doesnât care where the data came from, only that I has it.
Ok, so how do I inhibit it from loading SRTM data? In mission planner, I load the GEOTIFF, create the waypoint plan, select terrain and then write. When I do this it automatically pulls in SRTM data?
ter_? is the terrain system. it could be srtm or it could be geotiff. it is the same thing. this is just indicating to say if it has terrain data or not. it doesnât care where the data is from. when you set the spacing to 1, it pulls from the geotiff, if available and uploads that at 1m resolution
Well its not working that way or it is parsing the GEOTIFF into SRTM folders. When I set resolution 1, I get an SRTM folder with 627 indicated on the Ter_Load field. And when I check the SD card there is nothing but a STRM folder. So is mission planner converting the GEOTIFF to SRTM data?
MP uploads what the autopilot requests using the best available data it has. in your case this will be the geotiff.
the name of the folder was simply because thatâs what already existed. it does not mean anything.
the terrain system was designed around the srtm system. if the folder on the sd card is called this, it agains doesnât mean anything, as the data it contains will be the data MP uploaded, which could be from the geotiff.
id be pretty confident that you already have your geotiff data on your pixhawk. its just the folder naming was designed and based around srtm. not geotiff.
Thank you for your time and patience as I learn more about one of the many awesome features of Mission Planner. I am amazed by its breadth and depth. Thanks for a great product and for being extremely responsive.
Alex you can do it with tiles or GEOTIFF both from global mapper. With GEOIFF you must select custom imagery under source in the upper right corner drop down. Then hit CNTL F to get the menu to upload your custom imagery.
I donât have mission planner in front of me and canât remember the name of each tile. I can provide more specify assurance when I get to mission planner, which may not be for another 24 hrs.
I am attempting to load in custom elevation data into Mission Planner so that I can have a better precision than the 100m google earth data. I loaded a 10 m DEM into Global Mapper, following your video tutorial and placing the derived GeoTIFF into the SRTM folder (and removing the other files). When I do this the upper right corner in mission planner says âinvalidâ and all elevation data is 0. I made sure the DEM was wgs84 beforehand as well. Any ideas on what went wrong?
Iâm trying to make a terrain following flight with my DTM custom map.
I have followed all the stages that you wrote here.
made geotiff 32bit floating dtm from pix4d to MP thru Global Mapper
insert it into the SRTM folder at program data - I saw geotiff elevation data on mission planner right after.
clean the terrain data folder from the pixhawkâs SD.
then write the mission to the pixhawk from the mission planner with the geotiff
And it still doesnât fly 40 meters above the terrain data from the geotiff,
The weird thing is that it doesnât fly 40 meters above the SRTM data either.
it flies something between with no constancy.
When I flew there with the SRTM data (before inserting the Geotiff), it flew successfully 40 meters above SRTM terrain data.
If someone knows how to help me it will be great. Iâm pretty stuck with the subject.
While I have your attention, is it possible to insert more than one custom map in mission planner? I wish to have max 3 atleast 2 custom maps in mission planner that show the following;
1 - google map tiles custom map.
2 - a DEM in a google map tiles format.
