Copter-3.6.5 has been released as the official stable version. The changes vs 3.6.4 are in the ReleaseNotes and copied below:
RC input related fixes:
a) Pixhawk4 SBUS input and Serial6 pin mapping conflict resolved
b) RC DSM sync bug fix (channel 8 could temporarily become zero, ChibiOS only)
c) Mode and Auxiliary switch range check to protect during FrSky SBUS failsafe recovery
d) RC protocol decoding for SRXL, SUMD and ST24 extended to all boards including pixracer and ChibiOS-only boards
Other fixes and minor enhancements:
a) SD Card reliability improvement (BRD_SD_SLOWDOWN param) and allow re-inserting card after boot
b) Pixhawk board LED fix (ChibiOS only)
c) Follow mode reports target distance and heading to ground station
d) Pixhawk4-mini safety switch and LED fix
e) Bebop2 build fix
DrotekP3 Pro support
Cube Purple support
Thanks very much to the beta testers who put their copters at release testing this update and reported back their findings so we could (hopefully) make this another solid release.
If you find any issues please comment below or open up a new topic in this Copter-3.6 category, thanks!
Great news! @tridge put a lot of effort into trying to resolve the SD card reliability issues. I think the biggest change was that it tries multiple times to use the card soon after startup (instead of just once) and it also has some recovery logic now if the SD card is removed and re-inserted.
Perhaps check the flight mode. If the vehicle is in Stabilize or Acro mode it is possible to arm and fly without a GPS lock. If it’s in another mode then could you download a dataflash log file and post it here?
Yes the copter was in stabilize mode. I always start in stabilize and then switch to position hold. But when the arming check is on ‘all’, how comes it doesn’t check for ‘all’ if it’s in stabilze? That doesn’t sound logical to me.
Also, I’m nearly 100% sure that in the past I could not arm my copter without GPS fix, even when in stabilize.
Is there an option to truely put the ‘prearm check’ to ‘all’, so that it checks everything not depending on the current flight mode? I’d rather not want to start, get to altitude and then be surprised with a non-working position hold modus…
Okay, thank you for the replies.
In this case I will set a geofence (I had set one before, I guess that’s why I wasn’t able to arm without gps fix back then).
MATEK 405 WING does not boot with this new firmware.
I tracked it down to I2C compass connection. If connected copter will not boot. If disconnected it boots fine, but obviously compass is not active.
3.6.4 works fine.
My compass/gps combo is Beitian BN 880p5.param (13.0 KB)
Thanks for the report about the Matek405Wing not working with the Beitian BN GPS/compass which seems to have an HMC5883L compass on it. I’ve tested with an MRobotics GPS/Compass which also uses the HMC5884L and it worked OK so I’m a little unsure of what the issue could be but we will try and see if we can figure out what’s going on.
I wonder if you could try loading an earlier version of Copter-3.6 onto the board (I see MP has Copter-3.6.2 available in the list of previous firmwares) and then tell me the COMPASS_DEV_ID parameter value (or provide the full parameter list or a log file when running copter-3.6.2)
@rmackay9, i restored back to 3.6.4 by compiling based on copter 3.6.4 tag from github. log attached.
compass dev id is 0.
let me also run the copter under 364 - log attached.
BTW - copter booted fine under the battery power after downgrading back to 3.6.4
BTW2 - based on the log (not params) COMPASS_DEV_ID, 466441
