Copter-3.4-rc5 is available for beta testing. Release Notes are copied below. As per usual, the firmware can be downloaded from the Mission Planner’s Install Screen’s “beta firmwares” link. It can also be downloaded directly from firmware.ardupilot.org.
Bug fixes, minor improvements:
a) EKF fix for yaw angle reset fix when switching between cores (AC3.4 runs multiple EKFs simultaneously)
b) EKF fixes when fusing range finder into height estimate
c) pixracer clone board IMU hardware issue work around
d) dataflash time-going-backwards fix
e) fix rate PID conversion (AC3.3->AC3.4) for single, coax and tricopters
Thanks again to our beta testers! We’re almost there.
I flew today morning and it was really awesome! No errors at all. No yaw issues, nothing.
The flight was 15m long to film a construction site to build a report. Mainly loiter mode. Althold ( and rangefinder ) looks perfect now. Not even a single hiccup.
Congratulations to all the devs and the community!
We’ll see what rc5 brings…we are really close…my Rate Yaw P again look very high and i am not sure is it from Autotune or (again) from PID conversions… "e) fix rate PID conversion (AC3.3->AC3.4) for single, coax and tricopters"
please check my post
no answer at all at my post…after all this tuning i think there is a lot of useful data in my logs but no one cares…thank you
Hi, I can confirm this. Board boots up, reports no error so far. Haven’t fly it yet, will take some time to assemble the copter around it…
Huge thank you!
Flew rc5 today on a stock Iris+ & 3DR-Y6. Everything was great. Takeoff and landings in Stabilize and PosHold. Brake, RTL & Estop all working as expected.
Tested Tower Beta:
arm and takeoff from App
Dronie
multiple follow-me modes (no altitude issues)
manual flight path capture and replay as auto mission
Tested QGroundControl on Andriod connected via 3DR radio:
arm & takeoff from App
guided “fly to” points on tablet
I really like the pre-arm messaging and layout now in QGC along with the configuration section, but that’s probably a post for a different section.
Fast IMU logging does not work anymore in 3.4. I found it to be very useful, especially when dealing with vibration in Gas/Nitro heli. Fast IMU logging enables us to do a frequency analysis of the IMU to figure out if the excess vibration is due to main rotor or something else. On inspection of the code I see that the routine “Copter::full_rate_logging_loop” has been removed. I was wondering why it is so. Can we please bring this back? Is there a reason why this was removed?
It was part of a bigger change to support having EKF2 do logging for proper replay. You can enable fast IMU logging by enabling LOG_REPLAY (and with EK2_LOG_MASK you can control which IMU is logged).
Spektrum Satellite support appears broken for PixRacer. I have tried 2 PixRacers and 3 Satellites. When pre-bound, I see serial signals from the receiver with a logic analyzer but no channels are detected in Mission Planner. Binding does not appear to work either. I monitor the VCC and the signal lines. There is no sign of the needed switch off on VCC and nothing ever happens on the signal line either. Same results on Plane.
Hi @pkocmoud,
Im using a spektrum satellite rx, works well, except the binding. For that i use an arduino.
But… it does not work with my clone pixracer.
I dont know the reason.
Br, m.
