Here’s some output from F405-WING with RunCam Hybrid:
Note: This line doesn’t always appear:
APM: RunCam initialized, features 0x007F, 5-key OSD
But the results afterwards are the same no matter if it does:
APM: RunCamControl MIDDLE
RunCam[ENTERING_MENU]: osd option
RunCam[ENTERING_MENU]: update_state_machine_disarmed(NONE)
RunCam[ENTERING_MENU]: ENTER_MENU,M:-1,B:0,O:3
RunCam[ENTERING_MENU]: OSD cable simulation event IN_MENU_ENTER
RunCam[ENTERING_MENU]: sending command: 2, op: 1
RunCam[ENTERING_MENU]: retrying[2] command 0x2, op 0x1
RunCam[ENTERING_MENU]: retrying[1] command 0x2, op 0x1
RunCam[ENTERING_MENU]: timeout command 0x2, op 0x1
RunCam[ENTERING_MENU]: response for command 2 result: 4
APM: RunCamControl HIGH
RunCam[ENTERING_MENU]: start recording(4)
Mode RTL
RunCam[ENTERING_MENU]: update_state_machine_disarmed(START_RECORDING)
RunCam[ENTERING_MENU]: ENTER_MENU,M:-1,B:0,O:4
Mode FBWA
APM: RunCamControl LOW
RunCam[ENTERING_MENU]: stop recording(4)
RunCam[ENTERING_MENU]: update_state_machine_disarmed(STOP_RECORDING)
RunCam[ENTERING_MENU]: update_state_machine_disarmed(IN_MENU_EXIT)
RunCam[ENTERING_MENU]: update_state_machine_disarmed(IN_MENU_RIGHT)
RunCam[ENTERING_MENU]: update_state_machine_disarmed(IN_MENU_DOWN)
RunCam[ENTERING_MENU]: update_state_machine_disarmed(IN_MENU_UP)
What I did:
- Moved assigned 3-position switch up an down (I used my RTL switch for testing)
- Moved aileron, then elevator
There is no RunCam menu appearing on screen, and recording on/off is entirely unaffected by my input, no matter if auto record is on or off.
Thanks for your efforts!
