Is there any way to add to the new firmware a function (like flight mode)to make compass calibration on field with a switch on the radio??
There is in 3.7, if you are or want to run that version.
It’s rc#_Option=62
Here’s more info:
hold throttle stick full up and full right yaw for 2 seconds will initiate calibration mode, you can then perform the compass calibration dance without a ground station, if that’s what you want.
http://ardupilot.org/copter/docs/common-compass-calibration-in-mission-planner.html
Didn’t know that
Thank you a lot
Ok, so this feature was removed since the 4.2 version.
So how can I now initiate compass calibration from rc switch?
Maybe there is some LUA function&
Don’t. Do a crude initial calibration the best you can and then use Magfit for the final cal.
