On the latest version of Mission Planner, set the following parameters:
I just use the cable that comes with it. in MP set the following to activate Can. I probably just use the Loc1 until you fly it a few times.
Good day, settings by Brandon are corrects.
On LocationOne the rm3100 is SPI wired directly to the MCUā¦ you donāt need be worried coz it will work as uavcan coz settings are written in the hwdef file.
The UART port is necessary if you want access the ublox but you need the ftdi cable.
Personally i donāt use can termination but you can add it adding a 120K resistor to CAN H and CAN L., but if you have another CAN periph you can connect it.
Thanks David.
I am just replacing one can device with another so my params should all be good.
I just was puzzled by the documentation showing an I2C port where none exists. I have reported it to MRO.
I suspected the compass would work via the can port. So now the question isā¦do I want to use it lol.
Just perform the compass calibration and after this you are ready to fly.
In hwid in Mission planner you will see that rm 3100 is recognized. Just in case you need the I2C with a little bit of DIY you can solder a jst gh connectorā¦ so you can add and i2c periphā¦
As long as the compass is seen via the UAVCAn I donāt need the I2C. I did report to MRO that the documentation is wrong on their site and they are updating it.
I will likely power the bird up tomorrow now that everything has been installed. Whatās going to be interesting is that I will now have 2 RM3100 compasses on this drone.
If they calibrate al right then the question will beā¦do I want to use both.
HI rickyg32!
I got a Location One GPS w / Compass and Barometer, and I am trying to take the data through CAN1.1 but it just sends a data frame, I would like to know what I should do to send me the data through CAN1.1, I am a Little confused, I donāt have a PX4 to configure it, I would appreciate if you could guide me a little about what I need to do step by step to acquire the sensor data. I would greatly appreciate it
Well l, ive done some flight in an area with some interferencesā¦ i donāt have found problems during flights with rm3100.
On all my drones Iāve set as primary compass rm3100 and as backup compass the second the one of the fcā¦
Hey Dave
Thats great to hear its working well for you. So you are using a secondary compass, interesting. I now have the onboard compass for the flight controller and two 3100ās . Perhaps I can use the second 3100 as the secondary. No idea at this point. But glad to hear itās working for you.
I have most of the upgrades done on the drone now. The pixracer Pro is installed and working. The Location one is installed and working. All things seem to be working but my FPV gear and I will look at that tomorrow. Then its outside for calibrations and then wait till lock down is over.
I am doing an fc with a Teensy 3.6 (microcontroller) and I want to obtain the data through the CAN bus of the sensor, currently trying to read it and be able to process it but the LocOne only sends a data frame that is not referred to. Iām a little lost, could you help me?
wellā¦LocOne is already CAN BUSā¦so better you look for an fc with the stm32,a dongle its necessary if you want flash a new bootloader and firmware and change the settings about your periph using UAVCAN GUI, but now you can adjust some parameters using MP.
Will you have a forum page to put yourself in context about UAVCAN sensors?
to configure in MP (Mission Planer right?), what should I do? Where should I connect the LocOne to my PC? via a USB-CAN Adapter?
