@Tridge, does one need Software w/InterLink-X Controller ($180) or Software only ($100)?
Kelly
You do need one of the USB dongle types. I use the interlink elite but I believe you could use the wired or wireless controller and your own transmitter
Iāve got a version where I use my own transmitter ( āRealFlight 7.5 Transmitter Interface Editionā ) , which is what tridge refered to as a āwired controllerā edition. Initially I had some trouble getting my transmitter to output a PPM stream to the module, but once I cross-checked my transmitter/s settings and looked what the output on actualy was ( used my oscope, but probably optional) , it was trivial to get a PPM pulse into the āinterface editionā that it found acceptable, and since then Iāve been simulating to my hearts content, no problem. So, that moeans, I can use the $100 software-only upgrade, as I have the āinterfaceā hardware already.
I downloaded the .RFX File. Imported it from the directory which contained the caupirinha2.TGA.
All custom ariplains are deletedā¦
When loaded this Model, it asks serveral things. About overwrite, rename ā¦ Colorscemes, names ā¦
Whats correct?
New File on Github not tested yet.
Will overwork File names, Tilt Name, Axes directions first, and then fight more to load it.
There is another issue with my RF8 which has nothing to do with custom made models.
When exiting the Editor, the Menubar on top is destroyed and only closing RF8 is possible.
This makes editing terible.
Perfect demonstration in the Vid to show the graphics issues.
Seems not important for a vectored tailsitter when one Tilt is turning wrong
Will have to analyse why, I put the axes according the conventions.
Yes, the model is 900 gr including battery.
Regards, Otto
Hi Tridge,
The new Model on Gitub could be imported without problem and works. Apears as C 7-3 in Custom Aircrafts.
But not flyableā¦
Found the reason, because using RF8 as standalone (no MP, yet) but could test the reaction
of the movable parts with the sticks.
Would have to setup MP as Simulator also, but later when the graphic works.
Great job to repair the Files in Binary.
Regards, Otto
great!
to fix that just follow the instructions here:
http://ardupilot.org/dev/docs/sitl-with-realflight.html
KnifeEdge have opened up their LINK registration page, so you should be able to do it now.
MP already has support for talking to RealFlight
Do you want me to do a demo video showing you how to load and fly the C7 model from scratch?
try using a 2D photofield instead of the 3D airports. I always use a 2D photofield of my local flying site at CMAC, not only because it matches where I fly, but also because it is less graphics intensive for my slow windows laptop
Also turn all the graphics options in the setting down to minimum
Had a short look (Repair graphic has priority) at this Page https://www.knifeedge.com/cart/index.php?main_page=product_info&products_id=181.
Didnāt check whats the function or target of it.
This would be great because your tutorial videos where very helpful.
Especially the part, setup MP for Simulator, connection to RF8. (or is this the target of the LINK)
But I must say, didnā read Using SITL with RealFlight ā Dev documentation yet.
Iām just a litle behind your recommendations.
Could be helpful for others.
But I know, you are havy charged.
Regards, Otot
try that first, Randy has tried to make it pretty clear
If you get stuck Iāll do a new video showing it using RF8 and your TVBS model
Cheers, Tridge
OK, of course will be next because the graphic works.(for me)
Here the new Files: https://drive.google.com/open?id=1PF47Lgz6Yc_jWSYbHD7esyJ7S_tCWs7o
The name of the .TGA File has to be maintained, because it looks after that in the file.
I selected, while importing, your Aircraft C7-3 and all Parameters where set.
Now, the aircraft only crashesā¦
Perhaps, a bottom start my be possible.
I use Carbon Props like this.
https://hobbyking.com/en_us/multirotor-carbon-fiber-t-style-propeller-10x5-5-black-cw-ccw-2pcs.html?___store=en_us
(Thy looks a bit less heavy)
Regards, Otto
fantastic, looks really great!
Iāve done a video here
Iāve also updated the RFX and parameters in the SITL_Models repo
Hi Andrew,
Iām happy that you are satisfied and thank you for the good video presentation.
You did the link to RF8 setup perfect. It can be used as Tutorial for others.
I did not compare the params you posted with mines yet. I find your Caipirinha flies more stable.
What about a non vectored Tailsitter, like Palm369, you know those with the ābutterfly modeā during auto mission.
I already made the raw drawings on the base of CAD Datas of him.
If you are interested I would complete it to the same state as my caipirinha.
This one:
For the last video I adjusted the tuning gains a bit to increase stability
that would be great!
Weāll need to set it up so it starts with the props pointing up like a tailsitter.
Thanks!
OK, will continue when I got the infos from Palm369
Kind regards, Otto
Cough, how about an Arduplane sticker on each of these modelsā¦ What was butterfly landing mode Otto? Shutting one motor down and sycamore seed rotating down might be fun. Cool take off mode after a stiff chuck.
Yes, thats a good idea with the sticker.
Whats the meaning of Tridge?
No not butterfly landing.
Butterfly flight mode like this.
from here:
Regards, Otto
Hi Tridge,
Here the Files for the non vectored Tailsitter of above.
https://drive.google.com/open?id=1s-iICWrAnf8E8c3NjexnqP4g8oTCzcrj
I didnāt get the specification from David so far.
But I hope you can use it with your own data.
I could import it to RF8 without issues.
But editing is still difficult, because crashing after āexit editā. Even with standard Models.
No answer from KnifeEdge Support so far.
And with this issue, will wait with the link to MP.
Try to install RF8 on another PC. May be Win7, 64Bit,Ultimate does not work with RF8.
Regards, Otto
Thanks!
I fixed a couple typos in the FBX file (using a binary editor):
Iāve now got the Cat tailsitter flying - it turns out RF8 doesnāt handle the german characters in the names. I did some more binary editing and I can now fly the model. Iāll do a video soon.
Here is a video of the Cat flying:
