I am able to connect to another set of BLHeli ESCs Flycolor cross 35A just fine (only one connected in this tlog) 2019-03-21 10-40-26.tlog (176.7 KB)
Am I missing anything?
Also, every time I attempt to connect for the first time, BLHeli Configurator tries to reboot, I see the message “ignoring reboot” then I try to connect again and it works.
This reboot problem also happens when trying to use the configurator motor test, which means I am locked out of the configurator motor test.
EDIT: Both ESCs configuration works fine when using a Mrobotics pixracer. Using the pixracer also gets rid of the anooying “rebooting FC” thing.
Can you confirm that SERVO_BLH_PORT=0 ?? This parameter is not in the utube videos. This defines the port used by BLH32 to communicate with the flight controller. Only the usb communication will work with BLH32, so any other setting will result in the message you describe.
Yes, I had the same issue with SERVO_BLH_PORT, the description is a bit confusing.
Try connecting with the BLH “log” enabled, it may give you more information. Can you spin up the motors? Not with BLH motor test, but with mission planner.
