@ppoirier Yes, you are right, after changing the I2C TFmini address successfully, it will be saved in the flash, even if it’s powered on again, it will not change this address. : )
Hello, friend, if you interested in TFmini with I2C interface, we have an open task to develop/add the I2C protocol to the latest firmware for APM developer, welcome to check.
TFmini I2C version Datasheet below:
02_TFmini-I²C-Datasheet V1.1 EN.pdf (401.6 KB)
Pls check my another Blog for more info:
Are you talking about a new TFMini module, with i2c support, or is it possible to take existing, Serial, TFmini and convert to i2c using the new firmware?
Cheers.
@Shao Hi, the TFmini module is with I2C support. And we hope to make it works with Ardupilot & Pixhawk directly. Pls check the Firmware Development Task file to know more. : )
Sorry still not quite clear - are you saying that at some point in the future I will be able to take my existing TFMini modules, purchased last year that are currently serial, apply a new firmware and use them as i2c instead, or will I need to buy new/different TFMini modules to get this feature?
no there is a new TF Mini that supports I2C.
The old one is still serial
Thanks Ricky. So for existing projects the converter is still the way forward if we want i2c? To be honest I’ve come to terms with using a dozen CP2102 usb-serial adaptors as these can power the TFMini too so not that bothered…
Do you know anything about whether the new TFMini Plus will support i2c out of the box?
Yes I am no expert but I know there is an I2C version. I have attached the tech notes on it.
I believe there will be two versions going forward. I2c and UART.
I am seriously thinking of moving to an I2C version so I am not taking up all my uart ports.
Enjoy the read.,
I did see that datasheet before; it’s a bit strange as it’s not listed anywhere on Benewake’s page so I was half-wondering if it actually simply refers to this product, which is just the normal version with an external serial-i2c adapter: https://www.sparkfun.com/products/14786
This seems a bit different to a few other discussions; one from Benewake talking about a task to add firmware support for the i2c, and to this image, which shows a TFMini (V1.5.3, no other markings) but talks about i2c addresses - I’m a little confused; can’t find where this image originates either…
At this point I would defer to Patrick.
I got an email a week ago about the I2C version. But Patrick is the pro on the subject.
I am guessing that technically both units could use the same hardware platform (see below), but this might not be possible for different reasons like support or warranty, @Siya might be able to answer.
They are sold as 2 different units @ sparkfun
See this is why Patrick is my hero
Plus he is Canadian…Thats an extra point for him lol
Yeah, feel like the Sparkfun offering confuses the matter. This device, part of that product, is a separate serial-to-i2c converter, produced by Benewaake, which would work just fine with any TFMini:
That’s not the same as the circuit in the other image, which appears to show an actual TFMini module that natively supports I2C (which is also what the thread about firmware elsewhere implies).#
My question, basically, is: Is there a separate TFMini module that supports i2c without the “boost” board? If so, where can one get it and other related questions.
This is not a Serial to I2c converter, it is a power conditionner + a I2C bus driver… look on previous posts above , I made the same wrong assumption
Aha. Thanks so much, that makes a lot more sense!
Hi, everyone. TFmini I2C version and TFmini UART serial version are two different versions, we could say they are different TFmini. : )
Thanks for the clarification Siya. That being the case, a few questions:
If there, or will there be, an i2c version of the TFMini Plus?
Is SparkFun currently the only place stocking the i2c TFMini?
@Shao Yes, TFmini Plus will have I2C version too, it will be ready after some time. Now Sparkfun have the I2C TFmini, other distributor will have it after some time.
New LiDAR TFmini Plus is developed based on TFmini, higher accuracy, higher frequency 1000Hz, IP65 weatherproof case, and can be found on IR-LOCK store:
I have tried this setup exactly as well as rngfnd_type, 20. Is 20 supported on 3.6.6 stable? In either case I only get Bad LiDAR health. I have tried ticking pix mode as well as sending the string of characters using the TFMini Tool. Any Insight?
For those here eager to test, I just submitted the PR to support TFMini Plus on I2C:
