Bad vision position with pymavlink command
i’m using mro pixracer-pro with arducopter 4.4.0, mavros and my position estimate is via visual odometry.
my sequence is set mode to guided, arm, takeoff to 1m, move 1m forward (in the yaw i had at takeoff)
this almost works, i get a good takeoff and start moving in the direction i want, but right after i finish my takeoff and give the move forward command i get a fcu error “bad vision position” and the drone doesn’t stop moving forward even after i cleared the 1m mark.
my code for motion:
def _move_impl(self, pos_x, pos_y, pos_z, yaw_rate):
    # Use Position :      0b110111111000 / 0x0DF8 / 3576 (decimal)
    # Use Velocity :      0b110111000111 / 0x0DC7 / 3527 (decimal)
    # Use Acceleration :  0b110000111111 / 0x0C3F / 3135 (decimal)
    # Use Pos+Vel :       0b110111000000 / 0x0DC0 / 3520 (decimal)
    # Use Pos+Vel+Accel : 0b110000000000 / 0x0C00 / 3072 (decimal)
    # Use Yaw :           0b100111111111 / 0x09FF / 2559 (decimal)
    # Use Yaw Rate :      0b010111111111 / 0x05FF / 1535 (decimal)
    # 0b, yaw_rate, yaw, 0, pos_x, pos_y, pos_z, vel_x, vel_y, vel_z, acc_x, acc_y, acc_z
    type_mask = 0b010111111000  # position and yaw rate
    self.autopilot.mav.set_position_target_local_ned_send( #mav.send(mavutil.mavlink.MAVLink_set_position_target_local_ned_message(
        10,
        self.autopilot.target_system,
        self.autopilot.target_component,
        mavutil.mavlink.MAV_FRAME_LOCAL_NED, #mavutil.mavlink.MAV_FRAME_BODY_NED,
        type_mask,
        pos_x, pos_y, pos_z,            # position
        0.0, 0.0, 0.0,                  # velocity
        0.0, 0.0, 0.0,                  # acceleration
        0.0, yaw_rate)                      # yaw and yaw rate
def move(self, pos_x, pos_y, pos_z, yaw_rate = 0.0):
    print("flying to: ", str(pos_x), ", ", str(pos_y), ", ", str(pos_z))
    print("with yaw rate: ", str(yaw_rate))
    self._move_impl(pos_x, pos_y, pos_z, yaw_rate)
Why exactly are you not using ArduCopter 4.4.4 or 4.5.5 ?
i’m trying to upgrade to an existing system and not add too many bugs in the process…
ArduCopter 4.4.0 has known bugs that 4.4.4 and 4.5.5 do not. You really should inform yourself about the software release and testing process used by ArduPilot.
