I have just finished assembling and configuring a quadcopter with the following:
500 mm across between motor centres
Pixhawk 2.4.8 FCU
900 kV motors & 1045 props
3S 5,200 mAh battery
Arducopter v3.6.11
AUW 1,480 grams
I have successfully flown it several times now, but it needs a completed Autotune to be more responsive and crisp. However, every time I enable Autotune (in Altitude Hold Mode), there is no “twitching” until I move a control stick. The first pass of Autotune is in the roll direction, but if I manually move the copter in any direction (roll, pitch or yaw) the Autotune will then give one twitch in the roll direction and nothing more until I move a stick again …
I have spent hours plowing through the log files but cannot find any clues as to what is wrong. I suspected excessive vibration, but the vibration levels appear to be OK?
I thought that the Ch1,2 or 4 dead zone might be too small (20) so I increased them to 40.
I then suspected the the 12" props were too flexible, so replaced then with much stiffer 10" props.
Then, I suspected the anti-vibration mount as described here (Autotune does not function unless input is given) so I removed the anti-vibration mount and fixed the FC with 4 small pieces of double sided foam tape. But, that didn’t help either …
I have previously built a similar sized Hexacopter and it performed Autotune perfectly. So I am at a loss to figure out what is wrong with this build.
Here is the most recent log file (https://drive.google.com/open?id=1NRnF0DAhdgLW1xIs4tTt_nBmgVO1o6rA) - I would welcome any suggestions or advice as to what I need to change or fix. This issue has me really puzzled …
