No logs (( flash chip full and at next reboot clear last logs((
What about airmod ? You can see that i’m did roll with throttle at 0% - and i’m think that this delay its not working airmod -
which should help control the copter when the throttle is at 0% - and in the end it just started to fall like a stone until I increased the throttle…
Maybe need increasing min rpm when armed?
In addition, for some reason, the commands with the sticks do not work - I could not start the compass calibration and the sticks do not start OSD did not try anything else
2022-04-20 19-21-56.tlog (81.9 KB)
Hello everyone I just recently completed my own 7inch fpv frame using arducopter. Im using the FR_7 v6 opensource frame and have managed to get a pretty descent tune through Andy’s series of videos however I am still experiencing the occasional vibration failsafe whilst flying aggressively. Maybe someone more knowledgable than I could review my log and give me some sage tuning advice. Please pardon my basic user level ignorance.
thanks for the very detailed build log!!
During difficulties tuning a Rekon7 i came across the question what about the FLTT params. Using the initial tuning spreadsheet they are set equally to the FLTD params. Above you are only talking about changing
ATC_RAT_RLL_FLTD and ATC_RAT_PIT_FLTD. How did you to set *_FLTT?
I have strong oscillations in act. PIDP/PIDR log and large deviations between PIDP target and actual…
Hey were you able to get Ardupilot on your Flywoo LR (assuming it’s the Explorer)? If so what FC do you have and what target did you pick? I have a newer one that I’d like to switch to AP, from the chip specs it should work but I can’t find any target close, its a Goku GN405 Nano.
Holybro F7 mini V2 (has to be v2!)
Holybro tekk32 mini (blheli32, only newest firmware works, or not all motors start every time)
Iflight gps v2 w/ compass
R9 mini (with elrs firmware)
Vista dji Air unit.
Flywoo 18650 4s pack.
Oh and I did remove the middle posts to get the FC to fit.
I also have a rekon 5” now with the same FC but I have a hglrc esc.
Ohhh gotcha, I was hoping you somehow had it working on the stock FC lol. I have a feeling I’ll just be rebuilding it with a new FC/ESC at some point anyway. Thanks!!
I would like to publicly thank @andyp1per and @Leonardthall for their valuable advice.
Acro on Ardupilot is not trivial at all, forget Betaflight, iNav and the like, here the thing is a little more complex but absolutely more versatile.
For now I have arrived here, we can definitely improve.
The setup is in the video description.
I’m not happy with my arducopter yaw PID setup on these acro small drones. It never seems to be dialed in, I’ve tried auto-turn setups a manual tweaks.
