54.6v its an ebike battery using the 150a matek sensor that supports up to 16s.
http://www.mateksys.com/?portfolio=hcs-150a
I have now connected a GPS. The map in Mission Planner shows me the location. But the map in Ethos has only white tiles with “No Map Data”.
I extracted the map data via prefetch in MP Planner and converted it with the gmapresizetool. Afterwards I copied everything to \scripts\yaaputelemetry\maps.
Nevertheless, no map is displayed, but my GPS position.
Edit: already solved … The map data belongs under bitmaps, not under scripts …
In the telemetry screen I only see the following entries:
RxBatt
RSSI
RX (is always 0)
GPS
Shouldn’t VSpd and other sensors show up there too?
Ethos does not provide yet a method of injecting custom sensor data from Lua
Ethos version, @yak-54 @Target0815 fixed a bunch of things, please download updated version from github
what should be the SD paths for the Maps and Audio and bitmaps ? for the X12S
Installation instructions added on github
Today i have been using Ethos 1.0.0c-dev on X12S for about 7+ hours change all my Ardupilot planes a choppers from openTX to Ethos the only thing i found i get every so often loading layout pop up on all screens and the sound stop reading out like flight modes after a bit
and can we disable DISARMED / ARMED flashing on the maps and message screen
Flight mode flyby over laps number of satellites may change to FBWA FBWB
same as AvoidADSB i would say anything over 8 characters it to big
All i can say Alex and testers is thanks
I have been waiting so i can move away from OpenTX as it only supports 16 Channels
ethos does 24 CH
Thanks A lot Alex for your time I think its time by coffee / wine red or white ?
How do you actually download all the files if there is no .zip file? For some things Github is somehow illogical …
Edit: some tools probably exist for this purpose. Herewith it went: https://download-directory.github.io/
Yes, that is clear. But take Alex’s link (directly to the Ethos directory). And then?
Hi Colin, fixed arming status over maps and messages, also corrected flightmode display, updated version is on github
Thanks will get it on my tx now as i have another day of transfering planes
Question in ethos when i do a telemetry scan it comes up theses sensor
F000
5000
5001
5003
5004
5005
5006
5007
500B
500C
50XX are from passthrough telemetry, F000 is listed as FACT_TEST_ID but no idea what the purpose is
Hi Alex,just a daft question,if I get a Frsky Tandem X20 to replace my horus 10s/rfd setup this latest script runs on the X20 and I should get long rang p;us your telemetry is that correct many thank’s on advance
i have been using this on ethos on x12s for weeks with RFD 900X TXmod works fine
i did test it on X20S works great as well
Thank you Colin,now decision wether to buy new radio as like my 10s+RFD setup.
