First of all are you using ArduPilot?
No, EdgeTX.
I thought I needed to run the dev version as it said EdgeTX in the notes?
Sorry, I meant on the flight controller, my widget requires ardupilot as flight stack, it will not work with betaflight or inav.
I asked because I also wrote a mapping widget dedicated to other flight stacks
My apologies I misunderstood I am using iNav 5.0 on my flight controller
Is there a alternate version to run with iNav?
I did the try the iNav version, but sti not sure what’s wrong. I can see my gps long and lat but the maps don’t load.
Hi Alex, from which version is the X18 supported?
I only have the X18 Simulator, no real radio, all my testing on X18 has been with Ethos 1.2.11.
X10 and X20 has been bench tested with Ethos 1.3.2 but works fine with 1.2.11 as well
I have a X18S with Ethos 1.3.3 and can test your script …
sweet, couple of more days and I’ll post a test version
This version can use the external serial port to process MavToPT frsky telemetry as an option
if you need a beta testing i will help
i would of like to buy X20s but its missing t5 t6 and siders L1 L2 and little module bay and 6 position switch i think that be the X20s downfall for FVP and UAV flying
Hi. Thanks for a fantastic piece of code! Amazing
On my system (FrSky x10 Horus with Ardupilot), the Flight Timer resets to 60:00.
Is it possible to reset this to 00:00
Thanks
Alan K
Hi Colin that is a very bad mistake by Frsky to do the tandem with a small modual bay as the RFD modual wont fit
Ethos full screen test/dev version for all radios (X10, X12, X18 and X20)
download here
Edit: updated to version 1.0.0c, please download this one
https://drive.google.com/file/d/1vLpQ1jCm52L7yKIRscQ0xpgCo7BZwAVz/view?usp=sharing
Notes
- Map zoom in/out by tapping top/bottom right size of the screen, on X10 no zoom control yet
- full screen message history is still missing/incomplete
feedback is welcome
Do i just use X10 files on my X12s ?
i did get this
my bad missed full screen lol i used the wrong screen
use the one that says full screen on it lol and not the one that looks like full screen and turn off the title as well for X12S
new Ethos version 1.0.0b that fixes an event handling bug (wheel, touch, etc)
https://drive.google.com/file/d/1vEKUP4H4YyUNqGL5lyJVPsH-iAa39Kv5/view?usp=sharing
yes go full screen and disable the title, please update to the version I just posted
yep i found that wheel bug first time i powered it on last night it went emergency mode was bit late to post the issue i just come on now to report it Lol
