Note for X9D users:
memory on older X9D (non 2019) is really tight, I created a lighter version of the artificial horizon and of the right panel in order to run the script on those radios, these versions need to be selected with the “min” option for center e right panel in the config menu, this is how it looks
In case anybody wants to try all upcoming features here’s my ardupilot dev branch with all frsky pending code included
one thing i found out today is don’t update archer M+ receiver above 2.1.0
it breaks telemetry on the Archer M+
I did update Archer R8 Pro to 2.1.7 works fine
Hi all,
I added a new right panel type for custom sensors, select “custom sensors” in the config menu for right panel.
I also added the ability to render a sensor as a gauge with min/max values (like fuel in the screenshot)
This dev version is available on github by downloading the latest repo zip of the dev branch
You need to create a new sensor configuration file dedicated to the right panel: modelname_right_sensors.lua (change modelname to reflect you actual model name).
An example of such a file is in the ZIP /HORUS/SD/SCRIPTS/YAAPU/CFG/yaapudev_right_sensor.lua
Note: user sensors rendered as gauges eat a lot of CPU so please only enable one gauge!
I would like to set up the yapoo LUA script on a TX16S in order to get the telemetry data on the radio screen.
I use RC on mavlink with crossfire and I get the telemetry data on the telemetry screen of the radio but not on the Yapoo widget.
Is there something that I don’t understand?
I’m unable to solve this problem with the informations found on internet…
Alex,
I’d like to request a script that displays a ground speed estimate. A wind speed indicator would be cool too.
Use case: we fly missions that require us to maintain a certain speed over the ground but also have to use the airspeed sensor in arduplane to accurately control the plane. I’m mainly a fixed wing guy and pitot tubes help a lot when set up correctly. I realize the library only allows one speed type but I think it can be calculated based on gps data. Thanks and great work!
@yaapu I’ve used this on the Jumper T16 and RM TX16S with no issues. I was just curious if there’s any known limitation for the X10S or X12S, i.e. memory, CPU etc… I especially like the idea of the X12S screen on top of the Tx.
Has anyone tried to succesfully to make YAPUU work through telemetry received via lrsexpress (rx = happymodel PP, EP2 or EP1 & tx = TX16S with lrsexpress external module) ?
ExpressLRS telemetry works with Betaflight. Since Betaflight is opensource, couldn’t we copy the piece of code reading/parsing this proprietary expresslrs telemetry format to include it the yapuu lua scripts ?
Hi Hughes, it’s not proprietary, ELRS uses CRSF as telemetry protocol but they did implement only a subset of it, a minimal portion to allow betaflight to work but not ardupilot
