Tobias please be as specific as you can and provide OpenTX,Ardupilot and Yaapu versions.
thanks
thanks
so how many is it now and how many more do you think we need ?
Hi Colin, it’s a bug in the current scheduler, as soon as the rx polling slows down some info are dropped along the way, I explain it here
I redesigned the scheduler to overcome this kind of issues but haven’t submitted the PR yet, I asked you to open a bug report so the dev team could have a reminder.
I opened an issue for you, you can add you own comments if I missed something
Forgive my ignorance, but I noticed that the new FRsky RX4R receiver has an “Inverted S.port” solder pad on the opposite side from the connector.
…Does an inverted S.Port signal direct from the RX eliminate the need for the special cable?
see the manual for this “inverted S.Port” pad:
Hi all,
this is a test release of the mapping functionality version 1.8.1 beta1
horus_1.8.1_beta1.zip
features:
Setup guide is here
EDIT if the mktiles.cmd file was missing please redownload the release zip, thanks
I don’t have that receiver but you might need a diode if the FC board is not capable of native half duplex
looks good is there any way to install this version as well as the 1.8.0 and just select which one to use on a model ?
Where do i find mktiles.cmd script ?
Colin,
I published an older link, please excuse me.
If you download the release zip now all files should be there.
Ok, I’m now updating my versions where 1 year old:
Arducopter: 3.6.11
Taranis: OpenTX 2.2.2
Script: Taranis 1.2.3
good, version 1.2.3 is a really old one:-)
Yes, was already great back than, so no need to update
I think the update solved it. Not sure, will try tomorrow when I’m outside.
I’m now running:
Arducopter 3.6.11
Taranis OpenTX 2.3
Script Taranis 1.8.0
I think it might be possible that really old versions might not work with Arducopter 3.6.11.
Thank you very much!
OK great and you’re very welcome!
Hi Colin, the GPS sensor is missing, you need to do an “OpenTX” sensor discovery.
The radio is not receiving GPS coordinates from the FC,
Indeed. Remember to start the discovery of sensors and then go back to the widget before going back to the discovery process to stop it. That stumped me for a while as I was still in Taranis X9D mode.
Hi Colin, glad you made it work!!
[Q] The old yaapu widget config file did interfere with the new one? Do you still have a copy of that file?
no i just deleted it off the TX
