Hi Alex hope all is well in your part of the world
yes it binds fine
the X12S flashed with 1.4.9
the R9M 2019 is flashed FW-R9M-ACCST-20190117 using flex
and R9 is flashed with FW-R9-ACCST-20190201 using flex
and the ISRM-S-X10S if flashed with FW 2.1.6 (FCC)
and the HW: 1.1.0
yes it works fine on openTX and EdgeTX as i said
to me it looks like there is an hardware issue with frsky passthrough in module bay board with ETHOS SYSTEM OS
Hi, I check for telemetry packets with an ID of 0x800 which are sent by Ardupilot simulating a frsky GPS sensor and plot them as coordinates, do you have the GPS sensor in the telemetry screen?
I have no idea how to reproduce the issue
on X20 works both radio+simu,
on X12 and X10 works both radio+simu,
on X18 simulator works but not on radio, not sure here if ALL X18 have the issue or just 2 damn, frsky should send me all possible radios
-- gps status, draw coordinatyes if good at least once
-- if status.telemetry.lon ~= nil and status.telemetry.lat ~= nil then
drawLib.drawText(380, y, status.telemetry.strLat, FONT_STD, status.colors.barText, RIGHT)
drawLib.drawText(380, y+12, status.telemetry.strLon, FONT_STD, status.colors.barText, RIGHT)
-- end
… the value there is “N/A”. In other words, nothing is displayed because there is supposedly no data.
Hi, not well
My R9M 2019 flashed with D16 does not enter bind mode (not led flashing on the back) if I move the very same module on another radio (tested on many of them) it works and enters bind mode, so not sure what’s going on.
I’d probably flash my upgraded X10 to OpenTX and check that config
Yes, same problem R9m access firmware. In sensor discovery i have all the sensor discovers sent by the flight controller but none discovered by yappu app.
Hi, my scripts and widgets DO NOT use sensors, they rather use passthrough telemetry.
The only sensor used is the GPS one.
What is your setup?
Which radio, yaapu script, ardupilot, edgetx/opentx/ethos version?
Which RC and telemetry protocol?
Os:Latest ethos
Transmitter: x10s
Protocol: excess
RX: r9mx fport config
Tx:R9m
Yappu ethos latest script
It has been working ok on opentx. Now I am using Ethos,early this year open tx version has lot of issues such as telemetry lost where signals are well established.since I have switch to Ethos no more telemetry lost issue.
Note: all the sensors are discoverable at TX side when runnyappu no info getting update.
As I previously wrote
Twin X-Lite Ethos with R9M 2019 Access firmware. Yaapu ethos script. Ethos 1.4.8
Ardupilot, receiver R9MM, R9Slim+OTA, access firmware, configured as FPort.
In this configuration Yaapu screen not working, but working Telemetry Viewer via internal Bluetooth (it work with passthrough telemetry)
Twin X-Lite Internal TX module in Twin mode with TW-MX receiver FPORT - Yaapu screen working
Twin X-Lite Internal TX module in X mode with RXSR receiver FPORT - Yaapu screen working
installation instructions are outdated on github would be nice to update them specially now that the folder structure of the zip file contents in master have changed and there is an additional SRC folder as well and there are 2 folders for bw212x64_f2 and bw212x64_f4
Hi
SRC is always been there for black and white radios but it has been removed for color LCD since it’s not required.
The wiki should be up to date, I updated it when I changed the folder layout back in February, there’s always room for improvements so if you spot inconsistencies please suggest a fix
