here another user with the futaba:
Might worth to try using a logic analyzer, that will provide info about voltage level and signal.
Actually, as far as that goes, I used the GV-1 back in the day on my nitro heli and it didn’t work all that great, period. The only way I could get it to work at all was to use the RSC_SETPOINT feature and the rpm was all over the place. The old three-point throttle curve worked better than the GV-1.
I used the align Governor sensor but no luck. No rpm being shown… either the sensor is faulty or I have installed the magnets wrong.
Is there a correct way to install the magnets?
The distance between the sensor and magnet is less than 2mm.
The align had a different connector, all I did was cut that and solder a servo connector to its end to connect it to aux5.
Lost as to what’s happening!!!
Thanks and Regards,
Adarsh
Take the sensor off, hook it up to either a oscilloscope or even just a multimeter and measure what whappens when you wave a magnet in front of the sensor.
Is that some error for GPIO?
I fall back firmware to 3.6.12 and it work
@jinchengde and @Adi_Fly I think we need to move this to the Copter 4.0 thread. Since this sensor works in 3.6 and doesn’t in 4.0, then there is something that changed in the code that is causing a problem. I will start a post in Copter 4.0 and reference this post thread. Thanks to @jinchengde and @Ferrosan for doing the investigative work.
@jinchengde that GPIO_ISR internal error is triggered when we see more than 10k pulses in 100ms, so a rate of 100k pulses per second, which would be 360000 RPM. The reason we check for this is that interrupts take priority over all threads, so if we get too many interrupts per second then we get starved of CPU for flying the heli. I chose 10k per 100ms as at that level we are using just one or two percent of the CPU for interrupt handling, and it is a level beyond any reasonable RPM value. If we didn’t have this check and the number of pulses per second went over about 700k/second then you would fall out of the sky as there would be no CPU left to fly with.
There are a few possible reasons this is happening:
Ideally we’d get a trace (eg. oscilloscope trace) of this pin when the problem happens.
I finally managed to get the align sensor working for the rpm… now the rpm is being displayed in the gcs… next is to switch on the Governor mode.
Thanks guys… will keep you posted… but ya the futaba sensor is def a no no till it’s rectified…
Thanks & Regards,
Adarsh
Hello Adarsh,
Can you please advise how did you manage to get reading from the Align RPM sensor?
I’m trying but with no success.
Thank you
Rotem
Sorry for the late reply.
I think I had a faulty sensor which I removed from my old helicopter. I ordered a new one and it’s working.
I installed a aerospire gov sensor on another Heli, and that’s working too…
Thanks again for all the help everyone.
Kind regards,
Adarsh
Hello Adarsh,
Thank you for your replay.
I think mine is faulty as well, I’ve ordered a new one.
Rotem
@ChrisOlson see post 28 in this thread from @tridge. He had thrown out some ideas on what could be causing the problem but needed some one with an oscilloscope that could help troubleshoot. If you could support this trouble shooting, I’d really appreciate it. I don’t have an oscilloscope and I am not seeing this issue on my controllers.
@tridge what exactly do you need to see on the oscilloscope. What would be the setup in order to do this test? Here is the post on what Chris found.
@tridge this is serious bug that will impact tradheli users that want to use the existing governor in 4.0 and the improved governor that Chris Olson has been work on for 4.1.
Hi @tridge and @bnsgeyer,
as discussed with Bill I report here what we have observed on our setup:
-Flight control: CUAV Nora, powered by CAN HV power module;
-Servo Rail: connected to external BEC set at 8.4V;
-RPM sensor connected to servo rail and RPM_PIN set to 63: https://www.sm-modellbau.de/magnetischer-Drehzahlsensor-fuer-UniTest-2-UniLog-1-2
RPM sensor is working (led changes status upon each magnet passage) but reading on the flight control is not.
If rpm sensor is powered instead by external 5V power supply with ground and signal connected to flight control, rpm reading in the flight control works.
Sensor itself outputs 3.3V level signal.
Additionally, we noticed on this flight control that the servo rail voltage is not logged:
I assume you mean pin 53?
Since all modern digital tach’s are pulse train, what is the thoughts on implementing a pulse train frequency counter in the Heli RSC specifically for the governor and rpm functions in heli, and not use the RPM library with an interrupt? The RPM library was originally written only for logging and was called from the main code at 10Hz. I increased that to 40Hz for the governor, but it is still not ideal and really needs to run at 400Hz (or main loop rate) with the rest of the governor code.
no Chris, it’s connected to pin 63, I followed this:
Also, we have a fuel flow sensor connected to pin 62. They both work fine if powered by a 5V source, otherwise if powered by the servo rail (HV) straight the autopilot doesn’t read anything.
Both sensors are rated for HV power supply, as side note.
I will try stepping my sensor drive voltage down to 5V and see if that works.
That did not work to reduce the drive voltage to 5V on the sensor. Further, I do not get an rpm signal from the RPM library with the Pixhawk 3 Pro on ChibiOS with Copter 3.6 either. It only works with NuttX.
Chris, sorry to hear that. On our Drotek Pix3Pro it works fine with 4.0.5 (using the same sensor as above linked). Furthermore, on the pix3pro it is powered directly by servo rail which runs on HV.
In our scenario, only the CUAV Nora shows no readings if sensors are powered directly from servo rail (but sensors are working, we checked with a logic level analyzer).
