Thanks for asking, Risto.
The cause of the triple red LED blinks was a faulty flash chip model. The faulty chips cannot be tested out during functional tests and QC process at that time. So we stopped buying from that chip supplier immediately. And then added a new process specially for the flash chips.
This little faulty indeed brought us a lot troubles.
However, if the system does not blink triple red, then please feel free to use it. I don’t think we still have stock of finished products with that chip by end of Feb. @Jim_C 's system was shipped out on Feb 17 and it is the late one reported with the issue.
Not sure if time has anything to do with it but for me, even though our calendar days are roughly the same, I didn’t have much hourly time on the package. Due to various delays I had maybe a couple hours max before air unit failure then an additional couple hours max on ground unit. So, at old man piddling around pace, pretty quick time-wise.
sorry I know I asked, but is it approved fcc with what antennas? do you have a combo fcc approval like a high gain antenna with this hm30? or is it fcc approved with the standard antenna? also what range do u typical reach with the standard antenna?
Hello, I’m in the store
Official Store bought a set of HD link, the order was made on 08.12.2021, at first the system worked correctly, the connection was going on and all the indicators were normal, after a while the ground unit began to change the indication from blue to red and this began to happen more and more often. Now the connection is happening, but the ice on the ground block does not light up blue… This system did not even fly on an airplane, all the changes occurred in the system that was lying on the table. Unfortunately, I was unable to update the firmware, it is not very clear why there are such difficulties with installing drivers вывод - YouTube
