I just updated to 3.6.6 and i started getting Bad GPS Signal Health.
Both receivers have 21 sats and hdop is 0,6 on both.
I have blend configured. If i deselect blend it stops doing it but as soon as i select, use best or blend it restarts.
Only way to not have the error showing is to disable auto_switch.
With auto_switch disabled the system works with one receiver or the other without probs, so it is not hardware related.
I noticed in the messages the system doesn’t write “GPSx specified as UAVCAN”
Would really like to try going back to a previous release but i can’t find it trough MP
An update on my investigation. It looks like whenever i change serial 3 settings from the usual 5 38 to something else it starts to give health error. I use uavcan so i tried to use serial 3 for another sensor and that is where i got the message.
Once i put serial 3 back to default error goes away even if i don’t connect gps to it as i use only uavcan.
mike
(mike kelly)
March 5, 2019, 5:07pm
3
Not exactly sure what you are doing but
You know that you can not use 2 UAVCAN GPS, right?
You can’t use blend or switch with just one GPS?
I am using 2 uavcan gps, why i can’t? Maybe i missed something.
rbachtell
(Randy Bachtell)
March 6, 2019, 1:40am
5
I have also used dual Zubax with no problems
rbachtell
(Randy Bachtell)
March 6, 2019, 1:43am
6
Steri, did you come up with a solution to the long boot time for the Zubax compass prior to a firmware update from Pavel?
I am not sure what bug you are referring to.
It looks like there is a bug when using blend and NOT using serial GPS that generates bad gps health mesages:
Corrado
rbachtell
(Randy Bachtell)
March 6, 2019, 10:20am
9
Sorry Steri, I got you mixed up with another Chap on the Zubax forum that was having the same issue as we are having.
