ZR10 2K QHD 30X Hybrid Zoom Gimbal Camera - SIYI's first industry gimbal camera and it won't be the last
The firmware is missing in the link provided…
Thanks for your feedback
The camera firmware file is fixed now
@SIYI @rmackay9 - I managed to get the camera functions (zoom, focus etc.) working in MP with a joystick using the ardupilot latest firmware (and latest ZR10 firmware). However, the zoom functionality seems to behave in a strange way at the transition between optical and digital zoom (tested with different joysticks and both the absolute and normal zoom setting for the ZR10).
With the joystick pushed to increase zoom, the optical zoom phase is smooth - it stops at 10x. I then have to move the joystick back and forth repeatedly in order to increase into the digital zoom - it stops multiple times before reaching 30x.
I don’t have any issues when utilising the SIYI QGC zoom function so it is not the hardware.
Any suggestions?
We already have a firmware for ONVIF streaming, would you like to have a try?
That is very good news. And it does come in a good time. Thank you for persuing this.
Do you have a ZR10 on hand for testing? To make sure that it is the exact thing you need.
No, we unfortunately don’t have one.
Hi @birdperson,
Thanks for the report. @khanasif786 is going to try and reproduce this issue.
in the new firmware, autofocus is broken in the process of changing the optical zoom. Siyi, do you test your firmware before release?
Old firmware:
New firmware:
I have successfully upgraded the gimbal and zoom firmwares to v0.3.0 and 0.2.2 respectively but I am not able to upgrade camera firmware to v0.2.9 by following the steps mentioned in the user manual.
I am attaching video of the error and image of the updated firmware for your reference. Kindly help me solve this at the earliest possible.
https://drive.google.com/file/d/1OtXlrnBD07q1CFz-bVjklF9EzmQYGFSk/view?usp=sharing
Hello, Can anyone share the bin files of the previous versions of SIYI ZR10?
The required files are these:
ZR10 Camera Firmware v0.2.4 svn svn306 2022-08-02
ZR10 Gimbal Firmware v0.1.7 svn6006 2022-08-02.bin
ZR10 Zoom Firmware v0.1.5 svn6007 2022-08-02.bin
Hey,
Can you please share the bin files of these?
Your zoom firmware and gimbal firmware look fine. Camera firmware should be updated through SD card
Hi @SIYI ! I just wanted to let you know some things for the Camera FW v0.2.8 + Gimbal FW 0.2.7 + Zoom FW v0.2.1. I did not upgrade because of the post above.
  1. Whenever I capture an image, no matter what microSD card quality I have, what format, or if I have set the min. storage unit to 64 KB (as suggested above) I still have images that are not fully saved, as I I wrote here.
  2. The images do not have coordinates or time in their EXIF file. The autopilot is set exactly as per Wiki.
These issues have not been addressed in the new firmware. Any plan on doing so, or how to currently solve these issues?
Thank you!
@birdperson
Here is a fix for this. Tested on Zr10.
Hi, i have the latest firmware(gimbal 0.30 camera 0.29) but i keep getting the same problems with camera drift. Maybe I need to specify something in the settings?
Hi @SIYI! For our task, the time of obtaining a frame is critical. Now, depending on the weather and lighting, the camera itself selects the desired shutter speed. Is it possible to set the shutter speed through your SDK or is it possible in some other way? VISCA?
The camera randomly starts rotating a few seconds after being pointed down at 90 degrees.
Sample video - gimbal.mp4 - Google Drive
@SIYI , Hi Frank, unfortunately I must second this discovery
@skyAlex @champ8242
I assume that the video of the new firmware is SD card recorded, right? If you both see the same gray pixels, please check SD card format (FAT32, minimal storage size 64KB should work fine).
