I thought i had a compliant mount yet I have issues. Perhaps I am not compliant enough. Perhaps too hard still, maybe something more flexible.
The âOâ rings go through the native amount holes in the Pixracer, yes.
These are the two sizes of âOâ rings I purchased but use the smaller one most of the time, with a 1cm distance between hole and standoff they provide just the right amount of tension, and as you saw, with the heavier Cube mount I just use 2 per corner.
Not sure about hardness, have not really seen any references to different hardness for silicone as there is for butyl.
This site just wonât let me upload a pic straight from the camera, some glitch with jpeg sizing.
Sorry about the low res.
Here is another reply I did with details on vibration mitigation.
I find the upload function on this site a pain in the patutie.
Even files that are smaller then the limit fail when I try to upload. So I open them in MSpaint and use the resize function. I then resize to 25% and save the file under a different name, usually it ends in SM to indicate small and then upload that. This method seems to work just fine and I have no issues with it.
But itâs the only way I can get it to work.
I will give the photos a good going over this evening. Just back from the dentist. AT 18 months of lock downâŚumâŚneeded a bit of work lol.
Yea I had a cracked tooth that i was able to talk the Dentist 3D cap it even know it was close to the root. I love the Ceric machines. Ok to bad about your vibration and sounds like your set on the soft mounting. wish you luck,. If you had Photoshop all you do is to lower the compression value to 4.
here is a old tip from the cube page from the designer of the Cube [Philip Rowse) âHard mount your system on a rigid frame. if after doing this, your logs show that you are having vibration issues⌠then get assistance in designing a correct isolation mount. This will only be needed on the 1% of strange frames or petrol vehicles. always get high speed logging data before attempting to use additional isolation.â
Philip later changed his view on this and I am sure he regretted stating that.
Itâs still on his FB page, in the 6 years making custom drones i never once needed to soft mount unless it was a little 3m tape. but i manually tune my rigs as well.
Low tech damper with acceptable vibe:
https://drive.google.com/file/d/1-U4AZpeMDrMRRLl_derXzfHB2TmAUo3T/view?usp=sharing
Please note that entire carrier box was damped!
Hey Brandon. Yeah teeth argh.
As for the vibesâŚNot set on soft or hard mounting. I just either need to find out why the vibes are being produced and stop it or come up with a dampener that worksâŚor both lol.
So your input is really appreciated.
See I tend to agree that hard mounting should be the way to go. The thing is I just donât know whats causing the vibes. While new more expensive props improved things. I still have levels I donât want to see.
I confess I keep wondering if the gimbal is the problem. So this weekend I am trying the O Ring solution and then I am goign to unplug the gimbal. I am wondering if at speed the gimbal is starting to chatter. I have the same gimbal on another drone and notice it vibrates at times. Something odd about the motors. I am replacing it down the road but right now need to rule it either in or out.
Well that works pretty well. Unfortunately wontâ work in my system. But thank you for the input. Everything is a chance for me to learn more.
cheers
Hey Mike.
So my o-rings came yesterday. I had made a poly carbonate mount for the rings the day before and so got it mounted today.
I had two questions. Did you ever have an o-ring break and do I need 1 or two for the pixracer.
So if I am seeing this correctly itâs hard mounted to what appears to be a 3d printed frame or shell.
I wish I knew what was driving my vibes so I could correct it and go hard mount. That was the way the bird was designed. To have the FC hard mounted.
I was wondering about the legs that could make some vibrations⌠could you test that?
Sorry wondering about the folding arms.
Ah the folding. Yes I suspect thats the source of the vibrations. That some how during forward flight they vibrate more then in hover. IF so not sure the cure for that but have been wondering about it.
One thing to add is when i would work on my CR dirt bike you have two adjustments coil and rebound.
