Hope all’s good with you.
Picking up on a thread from a few years ago about the hover 1 frame from foxtech.
I’m just building one and rather than trial and error I wonder if you’d be able to share anything you learned about the position and damping of the flight controller? Quite a few mounting options on this frame.
with very good performance in vibration mitigation.
I initially developed this method years ago, with the APM’s, which were quite sensitive to vibration as was the code back then, pre v3.2.1.
The ‘O’ rings are critical in that only silicone ‘O’ rings will do the job.
Next is the thin lead sheet used to increase the mass of the sprung pixhawk to tune out vibrations in certain frequencies. I found a simple 1mm sheet cut to size and sandwiched between good quality gyro tape gives a good consistent result.
DO NOT skimp when it comes to the gyro tape, and the Futaba gyro tape give the best results.
The main components of a flight controllers installation
As the Hover1 was such a quick build I didn’t bother taking any pics
These are just some close ups I did for the customer who purchased it for RC installation position.
