Hi @GRS26,
There are some mixed reports about whether the latest MP resolves the “evaporation” problem or not. For me (using the version printed below) it seems fine but there is at least one user who says that it is still happening.
Hi @GRS26,
Great that it’s working! It’s taking time but I hope we will add to the GPS_OPTION a bit that allows using the SERIALx_BAUD to achieve what you’ve done with a code change.
@rmackay9 That would be awesome. The name will need to be something different from SERIALx_BAUD since that currently refers to a serial port ON the flight controller. The new parameter will be for setting baud for the port ON the GPS end, but I know you know that!
I am very pleased with the GPS Yaw, so far. I have run my mower most of the day, some mowing, but mostly just tuning. The docs like Tuning Speed and Throttle — Rover documentation (ardupilot.org) and those following it are really excellent now. I may just not be remembering, but I don’t think the parameters were explained so clearly a year or two ago when I was just starting. It was very useful to go back through these. Thanks to all who have contributed to them. I know you have been key in that.
by evaporation , you mean the mp crashing it?
I want to highlight it only crashes when both receivers are connected, like I can connect the telemetry, but when both receivers are on, MP crashes
But I didn’t try this beta version of mp yet, monday I will try and report if still has errors
Yeah, I tried, but didn’t work.
I read the pdfs’ from ublox, I configured both my rover(standard board) and moving base( lite board) to send the right messages. When I set gps_type 1 and 2 to AUTO, the cube recognizes both board, and I get rtk fixed from both,but as soon as I set the gps type to 17 and 18 and reboot the cube, I get no GPS.
I don’t use auto config because it assumes the connection between boards is through the uart 2, but in my case that I am using a lite and a standard board, its between uart1 from lite and uart2 from standard.
I managed to get heading using fixed base, moving base and moving rover in piggy back configuration. The only problem I am having now is that the rover is sending me back the position of my fixed base, like if I move the rover, it’s position on mission planner stays still on the fixed base coordinates.
If I disable either message 1005 coming from fixed base, or message 4072.0 coming from moving base, it’s stops, but I lose fixed rtk status in moving base or moving rover respectively.
It seems like the fixed base’s coordinates are being carried over all the way back to mission planner. Does somebody has any experience with this?
Why did you delete all your previous posts? It was an excellent discussion and helps put your current struggle into context.
I’ve not seen that problem at all. You still have something significantly misconfigured. Suggest you revert the F9Ps to default and follow @jolivart’s instructions to a tee.
the expiration problem was solved when used the beta version of mission planner.
@Yuri_Rage you are also using a fixed base right? if possible, could you tell what are the messages in your setup, maybe that gives a light to what I misconfigured
I use auto configure and relay the messages via MAVLink. It’s always been that easy for me, so I’ve not really messed with uCenter. And I think maybe you’re overthinking it…
ok, got it,
It’s weird, I have no idea why the rover is sending me back the position of the coordinates of fixed base.
You can auto configure the fixed base in Mission Planner as well…
I have actually also seen this once about a year ago the first time I tested with a pair of UBlox F9 GPSs. It was very odd, the rover appeared on the mission planner map at the location of the base. I can’t remember if the icon on the map didn’t move or if it did move but it’s location was relative to the base.
If you’ve got a log I’m happy to have a peek and we can maybe figure it out. I also think it might be good to check that the firmware on the GPS is at least 1.13 (update instructions are here)
Hello, thank you for the offer, in this case to see the information of gps, which log should I use, the telemetry one?
I agree with Yuri that if MP will configure the fixed base for you, you should just let it. I do not use MP for my RTCM3 from the fixed base, so I did configure my fixed base in Ucenter. These are the RTCM3 messages I have enabled and all works well: 1005,1074,1084,1094,1124,1230.
oh i dont use mp for fixed base either, I connected a xbee radio module on my fixed base to send the corrections. I did the exact configuration.
@rmackay9
Here are the logs:
Onboard Log
https://drive.google.com/file/d/18V7kK0_14j8CWU9Q7w2lekxVvmo4GZD4/view?usp=sharing
Ucenter Log
https://drive.google.com/file/d/1EdFkmxjS_XUmu4oRqZY24FaY1tErldTk/view
I have no idea why this error keeps happening, I already redid the configuration from ardusimple a million times, it works fine without the fixed base, but as soon as it start transmitting corrections, the position in mission planner changes from where it really is, to where the fixed base is.
funny thing, if I enable ntrip on moving base, it does not happen this, but with fixed base it does
Yuri, I’ve been spending time reading…and reading…
I want to get the point where I’m comfortable buying the setup to get hands-on with software/hardware. I would kill for a wiring diagram and component breakout. I saw you had ProfiCNC Here+, but it looks like you’re now using the same F9P simpleRTK2Bs that Kenny is using. What I want to do is take the component and wiring diagram and research signal flow before I start down the configuration parameters list.
Is there a reason you went with a traditional servo instead of a linear servo? Maybe you just wanted to show off those sweet CNC abilities. I’m thinking a linear servo will be more durable.
